2001 Chevy Cavlier Front Turn Lamps
Home  \  Domestic Cars  \  2001 Chevy Cavlier Front Turn Lamps
2001 Chevy Cavalier
2000 Engine
I removed two bolts and loosened the lamp assembly (with headlight and turn signal) on the drivers side. The assembly does not slide out. Is there a trick to getting this out so I can replace the turn signal lamp, or should I just get a bigger hammer.
Thanks
posted by  asegal
After the bolts are removed, I believe it has to be lifted 'up' and then forward. The back rests in a groove and needs to be lifted out of it.
posted by  rangeviper
