in line fuel heater
Home  \  Domestic Cars  \  in line fuel heater
whats the easiest way to heat up a fuel line?
posted by  sethfdabomb
Why would you want to?
posted by  88GrandPrixSE
what is the point in heating up your fuel?? it would mean you need to buy higher octane fuel. you should try to cool your fuel. :screwy:
posted by  Zepplin89
Finally, something that makes sense(from a performance or FI stand point)...unless he has a carb'ed vehicle and the fuel is puddling in the intake, that would be most evident in a very cold temperature and with a failing heat riser.
posted by  Sick88Tbird
no one is going to run a car in sub arctic temeratures, and i dont think he has a carburator, otherwise this would be in classics, so there is no reason to heat the fuel. it would vapor lock, or at least reduce performance. :roll:
posted by  Zepplin89
the post dosn't say gas or diesel the only place i've heard of fuel heater's(warmer) was diesel engine's
haha, You obviously haven't been to Canada before :P, this winter we had a spell that lasted about 3 weeks that it was below -40C.
