89 cavalier from my uncle
Home  \  Domestic Cars  \  89 cavalier from my uncle
I just got an 89 cavalier from my uncle for free. i have to do some work on it my self. It will not hold coolant and it has been sittting for 3+ years. Should i be worried about a cracked block or could it be freeze plugs? :ohcrap:
posted by  antiJDM
What motor?
Freeze plugs should be the last thing you should worry about, there's never a problem with them. Cracked block is also very un-common, so those you shouldn't worry about.
2.8 and 3.1's were really bad for head gaskets. That's most likely what your problem is. It also could be something as simple as a coolant hose, or could be your heater core even.
Does the car start? Does it run quite bad? Is the exaust really white? Does the exaust have a "sweet" smell to it?
posted by  88GrandPrixSE
the car runs well although i never payed attention to the exhaust or the smell of it. i have a 2.8 liter straight 4. I live in illinois and i have cold winters so i was worried about a cracked block. I sure hope it's not the head gasket :ohcrap: :guns: :cussing:
posted by  antiJDM
GM didn't make a 2.8 I4, the 2.8 is a V6. So I'm guessing you're talking about the 2.8 V6.
I'd put my money on it being the headgasket since you have that engine, I've done 2 or 3 on mine. Blew up my old motor because I tried to get it home with a blown head gasket, so I've been through a lot of them. It's not so bad once you've done a few of them, only takes me about 4 hours to do mine now. The front one that is. I had to do the one against the firewall on a Cavalier not too long ago, wow, that was a lot of work, that engine compartement was horribly designed. To get the fan out you have to dis-assemble the air-cleaner, and take out the battery and sneak it through where the battery sits. Just an example of how well designed they were :banghead:
i'm absolutely sure that it's a I4, but it's 2.2 sorry my mistake
posted by  antiJDM
My info shows that in 1989 you could only get a 2.0L L4 or 2.8L V6...
posted by  DragonRider69
well then what the hell's going on here?
:screwy:
posted by  antiJDM
Well it's definetly a 1989 cavalier with a I4. i know this for sure because i have seen it. you see this imbicile is my twin brother. :oops: It's definetly 2. something, but not 2.0.
posted by  Zepplin89
Turns out who gives a flying leap about displacement when its not the head gasket but the heater core. Figured it out when we got it up on a lift and saw the runnoff from the overflow tank from the heater core. so instead of 120 for a gasket kit, it's just about 50 bucks for all the core and hoses. Yay! :thumbs:
posted by  BenRambow
