need scanner help
Home  \  Domestic Cars  \  need scanner help
anyone know what kind of code scanner I need for a Jeep grand Cherokee loredo '94? and where I can purchase one cheap?
posted by  chefchewy80
if you just want to retrive the code's you dont need a scanner(cycle the ignition key on off on off on the service engine light will flash the code (example 21 flash flash pause flash pause) but if you want to see info from the ecm and sensor's then you need a scanner check with a parts store in your area you will likely have to buy the scanner and an adapter kit/cartrige for jeeps
