simple question
Home  \  Domestic Cars  \  simple question
Will wheels off of a 4th generation camaro or firebird fit on a 3rd generation firebird? THANX
posted by  83transam
they should if the lug pattern is the same (4 or 5 lug) because they are GM and GM uses alot of universal parts. and if im not mistaken then wheels should be the same.
posted by  frizzal
As far as i know they will fit. I've seen many 2nd or 3rd generation Camaros and Firebirds with other 3rd or 4th generation wheels.
posted by  car_crazy89
Lug count isn't a pattern...
All you need to do is have the same amount of studs & the same lug pattern and you're good to go.
http://www.rsracing.com/tech-wheel.html#patterns
yes, but you might need spacers to make the offset right
both are 5 on 4-3/4" bolt pattern
posted by  dodger65
Ok thanks for the help...i think im gunna buy some 4th gen. wheels and try to make em work
posted by  83transam
