Sunbird PCV Location
Home  \  Domestic Cars  \  Sunbird PCV Location
I would like to replace the PCV valve in my daughter's 94 Pontiac Sunbird. Its a 4 cylinder 5 speed. Can anyone tell me where the PCV is located? Thanks for your help.
posted by  dejay99
You should see a large 90 degree rubber hose going to the back side of the valve cover. You may have to remove the air cleaner assembly for access. Look at it closely and you'll see that it has a split line. Seperate the two pieces and the PCV valve is hidden inside. It makes more sense when youre looking at the engine.
Thanks for your help. I had actually removed one end of the hose before, but didn't see the valve inside. Thanks again.
posted by  dejay99
