66 Mustang Steering
Home  \  Domestic Cars  \  66 Mustang Steering
Im doing the granada disk brake swap on a 66 mustang and was wondering if the centerlink and all the attachments will work for the mustang off of the 78 granada if you could give any info i would be greatfull
Thank you for the help.
posted by  jarstak628
I was wondering if you could find the "Introduce Yourself" section and use it BEFORE you start expecting help?
Yes I can.
As I recall, the centerlink on the Granada is too long (wide) to fit your Mustang. However you can do the swap by simply swapping the spindle/hub/caliper and the outer tie rod ends as the fitting in the steering arm for the rod end is larger on the Granada. Everything else is a bolt on.
Thank you for the help and the info
Now ill just have to look for some parts
