Ford 88 Bronco Eddie Bauer Edition HELP!!!!!
Home  \  Domestic Cars  \  Ford 88 Bronco Eddie Bauer Edition HELP!!!!!
Hi everyone, the problem i'm having with my Ford 88 Bronco Eddie Bauer Edition , is that it turns over, but doesnt start,
I'm not sure if its the Interia Switch? or spark plugs or what! i have no idea where to start, the starter seems to be , Any idea's?? Or advice on where to look for this problem? any help would be great! thanks guys
posted by  fordbronco
If it turns over the starter is ok. You need to check two things first spark and fuel The local parts store has a tool to put between the spark plug and wire that will show you if the plugs are working Next to check for fuel you should have a guage that will install on the fuel rail borrow one and it should have around 40 psi diagnosis from there will need a lot more explanation, so find out which one is lost first
posted by  Rhino77_99
