How would you adjust a the gap between a door and the side panels on a 83 Camaro?
Home  \  Domestic Cars  \  How would you adjust a the gap between a door and the side panels on a 83 Camaro?
My camaro's pasanger side door gap (behind the front wheel well) is smaller towards the top of the car and wider to the bottom, which is chipping my paint, and making the door difficult to open from the inside.. How would i go about fixing the gap? I believe that the person who owned it before me somehow got the bottom of the front passangerside panel (the rear part of the wheel well) dented in just a bit (cant really tell) would i have to hammer it back into shape or what? Thanks in advance
Firebreed
posted by  83camaro
Not that I really know what you could do to fix it, but I'd love to see your Camaro.
Here's mine
http://www.LevineXB.net/glory.JPG
posted by  CoRPS
What year? my clear coats chippin but ill take a pic and post it.
83camaro
posted by  83camaro
Here a side view of my Camaro, (And yes thats my 1992 Geo Prism parked next to it lol)
http://home.comcast.net/~firebreed/Images/car/mycar.jpg
and heres a pic of my hood, Clear coat Chipping and all, although its not as bad as the (Edit:top) is. :banghead:
http://home.comcast.net/~firebreed/Images/car/carhood.jpg
posted by  83camaro
ok you could take off the panel find the little dented part and hammer it out, but b4 goingthru all that work have you just made sure to see if the panel is alligned properly? sometimes you can just shift a panal to make it line up try that first if not hammer the bitch :smoke:
posted by  camaro67
Ok, can you lift th edoor slightly on it's hinges when it's open? Those cars had a tendency for the hinges to get worn easy (the doors are rather heavy) and then they tend to sag.
While the proper repair would be replacing the hinge bushings, you can adjust it, as well. If you open the door all the way, you can see some of the hinge bolts. But the ones you really need to get to are under the kick panels in teh footwell ahead of the door. Leave the lower hinge fairly tight, loosen the top hinge (3 bolts) and move it forward a tiny amount (this will pivot it on the bottom hinge and bring the rear of the door upwards).
You can also adjust the door striker upwards a tiny bit to match.
posted by  ChrisV
Thanks guys, i will try that out, (Quick note if you look at my last post, and look at the top pic you can see the gap that i need to fix :D)
83camaro
posted by  83camaro
Ok, I had it backward. the front gap is what your'e working on, and that particular direction is a bit odd, so it's not caused by sagging hinges. Don't move the hinges forward at the top...
Is teh gap even at the back and down the bottm? Is the window still lined up with the window seal?
You wil indeed have to fix the front fender. Pull the lower part at the bottom of the wheelwell ******d. If you do it right, it should pull the upper fender away from the door AND make the lower gap smaller (which is what it should have).
posted by  ChrisV
The window has just Started to come out of alinement (hitting the side of the door everytime i roll it up, but im gonna fix that as soon as summer comes, too cold right now, Only in the 40's where i live and no heater where i would be working at) the gap is a bit big on the bottom (maybe 1/8 bigger then the other side), Ill print out this post, and let you all know how it goes when it gets a bit warmer out side
83camaro
posted by  83camaro
