Secret Weapon!!!
Home  \  Domestic Cars  \  Secret Weapon!!!
was thinking of getting this for my car but im not sure ...tell me what you think.
SECRET WEAPON INTAKE
The Secret Weapon Intake Systems is an result of countless hours of testing and tuning of air intake velocity, Airmass and Airspeed for each vehicle application. The Result, an intake system that performs better than any Cold Air Intake, but with a Short Ram. It is possible by Weapon*R's Patent Pending Speed Velocity theory, By creating a higher airspeed in the intake path you increase airmass and airspeed, which greatly increase horsepower.
This is possible by Creating two different paths of airflow, both flowing at different airspeeds, due to the tubing diameter in which the air is traveling. Now when the 2 different paths of air meet,they create a vacuum, which is where the airspeed starts to multiply, forcing more air into the engine at a higher rate, creating more horsepower.
The Secret Weapon Intake Systems are carefully CNC mendrel bent out of 6061 Aluminum, and then Hand Tig Welded in sections to ensure a constant balance in airflow, regulation in airspeed, positive seal and proper fittment. Each one of these intake systems are carefully tuned, by matching the engines displacement, air intake capacity and airspeed to the intake systems tube size,length and secondary pathway tubing diameters to maximize the full potential of the SECRET WEAPON INTAKE SYSTEM.
This Intake is Matched with our Newly designed SW1 Filter, which provides maximum airflow, with the protection of high quality dense Poly Urethane Foam. Many studies have shown Flow rates of up to 80% more Air and Better Dirt Filtration with Foam Filter than the conventional cotton filter. The SW1 main feature is an Computer CAD Designed and Flow benched Tested TURBO Velocity Stack, which greatly increases airflow ,airspeed and airmass into the engine, therefore increasing engine performance. Another one of the SW1 Filters great features are the capability to be dis-assembled to be cleaned and then re-assembled after cleanings or to change the color of the foam filtering element.
posted by  eclipsed420
http://www.rennenmotors.com/ebay/images/weapon_r_sw_intake.jpg
