Mercury Tracer 1992
Home  \  Domestic Cars  \  Mercury Tracer 1992
Hello hope everyone is fine, as for me my mercury tracer 1992 auto 4 door, is running so bad i haave two problems , white smoke coming out of the back , until it has warmed up, and it idles, , from up high, and down low over and over like its of time, but i have retimed it and still the same thing i have no idear what to try , any idea's ?
posted by  mindonni
White smoke can be a sign that you are burning antifreeze check level of the radiator and oil. The idle problem may be a result of this, it may also have a malfunctioning fuel psi regulator IAC motor or EGR valve sticking open Make sure your fluid levels are correct first. then let me know
posted by  Rhino77_99
