Need Cobra 427 Info
Home  \  Classic Cars  \  Need Cobra 427 Info
Hi,
I've been looking everywhere for information on either a '67 or '68 Shelby Cobra 427. What I need is the type of engine, Top speed, how fast it can go from 0-60, it's displacement, Max power--e.g. 425 bhp @ 6,000 rpm, Max Torque--e.g. 460 lb-ft at 4,000 rpm, and it's weight.
I'm also looking for some other information such as:
Transmission info
Body/Chassis
Running Gear including: front & rear suspension, brakes, wheels, and tires
and it's Overall dimenisions including: length, height, width, wheelbase, track front and back.
I would most appreciate if I could get this information. it's been extremely difficult for me to locate this information. I don't want modified engine info. I would like to have all original specs.
I can be contacted at KatheyESC@hotmail.com
Thanks,
Kathey
posted by  BlueButterfly
Technical specs for the original 427 Cobra
(street version)
Engine :
High-performance Ford V8 with pushrod-operated valves
Bore and stroke: 4.24 x 3.788 in.
Piston displacement: 427 cu. in.
Compression ratio: 11.5 to 1
Basic carburetion: Two four-barrel downdraft Holleys
Output: 425 bhp at 6000 rpm
Torque: 480 lbs/ft at 3700 rpm
Drive Train:
Four-speed Ford all-synchromesh transmission with floor shift.
Gear ratios:
First: 2.32 to 1
Second: 1.69 to 1
Third: 1.29 to 1
Fourth: Direct drive.
Clutch: Single dry plate (11.5 in.) with hydraulic actuation.
Chassis and Suspension:
Tubular-type chassis based on two parallel main members. Front and rear suspension: independent coil springs with parallel arms.
Brakes :
Girling discs on all four wheels.
Front: 11 5/8 in.
Rear: 10.3/4 in.
Steering:
Rack and pinion.
General:
12-volt electrical system with alternator
Wide-based, 7.5 x 15 in. wheels
18-gallon gas tank.
Weights and Measures:
Wheelbase: 90 in.
Overall length: 156 in.
Overall width: 70.5 in.
Tread (front): 56 in.
Tread (rear): 56 in.
Overall height: 49 in.
Ground clearance: 5.5 in.
Curb weight: 2150 lbs.
Standard road equipment:
Full instrumentation
Safety-glass windshield
Folding top and side curtains
Turn indicators
Genuine leather upholstery
Aluminum hand-formed body
Colors available: red, maroon, white, black, bright blue, princess blue, silver.
(racing version)
Engine:
Output: 490 bhp at 6500 rpm
Torque: 510 lbs/ft at 3700 rpm.
Cylinder heads were aluminum for the racing version, as opposed to cast-iron for the street version.
Optional gearbox ratios:
First: 2.32 to 1
Second: 1.54 to 1
Third: 1.19 to 1
Wheels:
Wide-based alloy.
Front: 7.5 x 15
Rear: 9.5 x 15.
Optional Equipment:
Special racing bucket-seats
Shoulder-harness
Quick-change brake-pad kit
Dry sump kit.
RESOURCES:
The Cobra Story: A Man, His Dream and His Automobile
Author: Carroll Shelby and John Bentley
1965, Trident Press
Carroll Shelby website
The Carroll Shelby Web Site
The official web site of the man who created the legend.
Includes biographical information, a historical timeline, information about new Shelby cars and products, news, links and more.
Web site: www.carrollshelby.com
posted by  corbett_auto
1966 Shelby Cobra Road-test results
0 - 60 mph3.6 seconds
0 - 100 mph8.4 seconds
0 - 130 mph15.1 seconds
1/4 mile12.0 seconds @ 118 mph
Top speed152 mph (redline)
Braking, 70 - 0 mph198 feet
Road-holding, 300-ft. skidpad, g0.99
"...14.5 seconds to accelerate to 100 miles an hour and then stop again. Until something better comes along, that may have to stand as some sort of high water mark in performance cars that are available to the general public. That figure, mind you, is obtainable by the average Cobra driver with regular street tires. Cobra test driver Ken Miles has done it in 13.8 seconds."
-Brock Yates on the 427 Cobra, Car and Driver, November 1965
Not sure the difference between 66 model and 67 model
Thank You soooooo much, if it weren't for your time and effort, I wouldn't be able to get this website off the ground. I think I'm going to give you a dedication in it for all the help you've given me. I don't know what I would have done without this information. I've gone as far as buying the Complete Encyclopedia of Classic Cars and it wasn't all that it was cracked up to be, well for me. So, thank you again.
Kathey
No prob, I enjoy helping :mrgreen: :mrgreen:
Check your PM....
What website? What will be the address when you're up?
posted by  DougB
