Chevy big block radiator question
Home  \  Classic Cars  \  Chevy big block radiator question
Hey guys I am running a 454 in my 72 chevelle I need to replace the radiator it keeps over heating even with the dual be cool fan set up I was just wondering I keep seeing aluminum radiators on ebay but most say small block chevy is there actually a difference or can I just fabricate a new mounting bracket and use one of those radiators?
Thanks for your help in advance guys
posted by  gto72
depends a lot on how crazy your 454 is set up... gears, etc...
posted by  dodger65
I am running around 550 hp with 410 gears so I assume I need some serious volume and flow but is there an actual difference in the radiators that say small block on them or is it just a mounting issue I dont mind fabricating a new mounting bracket just as long as the radiator will work.
Thanks again guys
posted by  gto72
most rad shops will custom make a rad 3 or 4 row = more cooling capacity
my buddy has a 305 w/ aluminum radiator and it runs about 10-15 degrees cooler.
posted by  adamc44
