Whitewall Tyres...
Home  \  Classic Cars  \  Whitewall Tyres...
what was their function? wat was soo special about them?
posted by  aman_s1ngh
Tires with white walls:
http://www.revelenterprises.com/images/SmoothieWW_small1.jpg
No real purpose, but they were all the rage in the 1930's-1960's...IMO still very beautiful, but only on classic cars :thumbs:
posted by  chris_knows
Umm, they're function was to make the car move and they are special because they give the car an antique look :screwy:
posted by  99integra
they look cool.....
posted by  windsonian
thanks chaps!
How about an introduction now :thumbs:
Bingo!
http://img.photobucket.com/albums/v325/vwhobo/092f5627.jpg
http://img.photobucket.com/albums/v325/vwhobo/5cf72596.jpghttp://img.photob ucket.com/albums/v325/vwhobo/19d5fffc.jpg
reliable type of suspension for back in the days automobiles? and are were they cheap to replace?
whoops! ya jus gimmie a sec ill head over to the introduction thread
1. Yes
2. It all depends
What is the point you're trying to get to?
basically im doing an assignment on the development of cars from the benz velo (1884) car to the car in 1970's... what im trying to find at the moment is the advantages and disadvantages of the leaf spring suspension system...
http://autorepair.about.com/library/glossary/bldef-456.htm
I thought this was kind of interesting
posted by  99integra
I have considered restoring a beetle with whitewalls... I reckon they suit it down to the ground (no pun intended). Unfortunately, being something of a classic, you seem to pay more than what they're really worth for a bug, and I don't want to do it that bad..... cool idea though. Was thinking something along the lines of ChrisV's avatar with whitewall tyres.
I too have a plan/idea for a VW Beetle (older) that I'd love to do something. I'd become kind of a custom (chopped top, suicide doors, white walls, etc) and would love to make fast to go along with its looks.
posted by  car_crazy89
Well, here's some info I've gathered....
Excluding the Corvette I'm aware of 4 general types of leaf spring suspensions.
1. Model T style transverse leaf.
http://www.dyna.co.za/cars/Ford_17_Model_T_sf66.jpg
This picture shows the transverse leaf used on a Ford Model-T. The suspension has two lateral arms that keep the front axle perpendicular with the chassis. Lateral axle movement is controlled by the spring. This system suffers from poor control of the axle’s movements among other flaws. I’m not aware of any production car that uses this suspension type. Basically, this was held over from the horse drawn buggy days.
2. Conventional truck type, longitudinal leaf springs:
http://www.carbibles.com/images/solidaxleleafspring.jpg
This is the one we all love to hate. It’s also about the only type of leaf spring suspension still in use other than teh totally unrelated modern Corvette setup. It’s cheep, durable and handles badly. It suffers from friction between the leaves and from poor control of the axle’s location.
3. Golf cart style transverse leaf spring:
I couldn’t find any pictures of this but it basically looks like a double A-arm where the leaf spring is one of the A-arms. The geometry is probably OK under vertical loads but lateral loads would defect the spring and cause camber changes. Not an issue for golf carts but bad for sports cars.
4. Leaf with links. There are lots of variations on this suspension
Miller Indy Roadster
http://www.scaleautoworks.com/millerphoto.jpg
Jaguar MkII rear suspension (can’t find a picture)
Like #3, these suspensions uses a combination of links and the leaf spring to support the axle. The Jaguar set up looks similar to a 4 bar solid axle rear suspension except the lower link is the end of an inverted leaf spring. The other end for the leaf is attached to the chassis under the passenger compartment. The middle of the upside down (frown rather than smile) spring presses against a rubber block. The end connects to the bottom of the axle. This system offers better handling and axle control than #2 but is still suffers from friction between the leaves of the springs and compared to multi-link live axles, poor control of the axle’s location.
What makes these all the same?
All of the above have several things in common. First, multi-leaf springs that suffer from friction between the leaves as the leaf flexes. Second, the inherently flexible leaf spring is being asked to work as a spring AND a suspension arm. Springs (leaf, coil, torsion etc) are good at being springs. They are bad at being other things like rigid links. In those suspension designs the spring is being asked to hold the axle and be a spring. To it’s credit, the leaf spring does this much better than a coil spring. How well would a coil spring do that job? Think of a bobble head doll. In fact, cars like teh Renault 4CV used their rear coil springs as locators for the rear swing axle, which let them pivot all over, making for not only interesting camber changes, but bizzare toe changes as well.
Just to complete the leaf spring picture, the Corvette's suspension changed after the period your report is about, and the composite monoleaf setup is extremely high tech, and vastly different than any of the buggy spring setups described above. First, the Vette actually has double A-arm suspension like many other high end sports cars. The A-arms are used to fully control the movement of the wheels. The only difference between the Vette and other cars with A-arms is the Vette uses a leaf to pull the lower arm down rather than a coil spring to push it down. In both cases the spring is doing what it does best, being a spring ONLY.
The other problem was friction between the leaves of a leaf spring. Well, the Vette uses a single piece leaf so there is no internal friction, just like a coil spring.
So what we have is double A-arm geometry just using a different type of spring.
posted by  ChrisV
http://i34.photobucket.com/albums/d148/guitar_outlaw_13/850frontsuspension- .jpg
This is what ChrisV was refering to as a golf cart suspension. This a Fiat 850 front suspension which is a slightly oversized golf cart(just kidding, I'm a diehard Fiat guy and I own 2 850's).
posted by  x1/9-rally
