accel electronic distributor backfires on 351c
I have a 73 351c and it runs great on stock distributor
when I put the accel model51202e
it backfires on accelleration I cant get it to stop backfiring
I have checked the position and no matter what it back fires
I am at a loss as to why and have pulled the dist a dozen times to check
the rotor position
I can put the stock back in and runs great
I made sure there was 13 volts to the accel and it still
backfires.
Thanks in advance for any help
Jeff
was the stock distributer points?
i had this problem putting electronic ign on my boat 460ford
ended up just running with the points
sorry i cant help ya
I take it you have the correct coil for dizzy e.g. MEC or HEC? Does your
dizzy have a centrifugal advance governor or does it rely on an ignition
controller?
When you say backfire are you talking about the exhaust or the carby?
Exhaust popping is generally caused by a lean mixture (vacuum leaks, gasket
leaks, over throttled idle cct or dirty jets). Backfire is generally caused
by igniting fuel in the intake ports or runners, caused by bad valve timing
or overheated exhaust valve or premature spark.
So to your problem, well I don't know because I'm not there, but have you
taken into account the increased energy of the coil: your ignition kernal
will be much larger than with points because of the higher voltage tension
and you may need to increase the plug gaps. Your plugs may now be too hot
and still glowing when the fuel starts entering.
You may also be inducing a voltage into an adjacent lead that just happens
to fire while it's cylinder is filling= cross firing. Magnecor 8.5s or
larger wire wounds are your friend.
What's your dwell when it starts carrying on?
Is the ignitor/amplifier the correct one for the number of cylinders?
Hows your acceleration pump plunger behaving?
Does the cap have any soot marks inside from arc burn?
Your primary current will almost double, is your wiring up to the task or
is there excessive volt drop?
And in keeping with the most obvious being the problem, are your leads in
good clean condition? Is the continuity ok when you give them a good
wriggle? Are the porcelains on the plugs crazed or cracked?
did you try just backing the timing off? how much initial are you running? how much advance was built into the stock dist vs. the replacement?
