For full features; Go to dry sump system?
hi,am thinking of dry sump system for 2.5 tuned spitfire.does anyone have
any views on this system?do you know anyone that has used this system,what
were there experiences,good /bad? any input gratefully recieved.:thumbs:
ukcjm@hotmail.c
What is a dry sump system, I've heard of it....I think something about the
Carrera GT....
It's a lubrication system mainly used in sports cars because it takes up
less space and stuff:
http://en.wikipedia.org/wiki/Dry_sump
hi matthew and chris knows,in addition the dry sump can remove air bubbles
from oil,heat up oil before firing up,help piston rings seal better by
producing vacumn in sump area,can adjust oil pressure,and keeps oil
controlled at all times.http://www.drysump.com/drysump.htm what do you
think?
ukcjm@hotmail.c
Good link, so basically a dry sump system is called dry because you don't
have a big oil pan at the bottom with a few litres of oil sitting there all
the time.
So now then, whats a 2.5 tuned spitfire? Sounds like an english car I've
never heard of....
or a WW2 fighter plane...
http://www.sportscarrentals.com/images/spitfirenew.jpg
Not sure if a Dry Sump system would be a big benefit on a Spitfire
though....
Are you rallying or circuit racing? If not why bother? Sure there is less
drag on the throws and counters, but it's very minor. If you are concerned
about foaming, change to a different oil. If you are worried about the
extra weight on the rods install a crank scrapper/windage tray combo.
I know it's probably your baby, but it's only a Triumph engine and if I
recall correctly the 2.5 V8 needed all the lubrication it could get from
it's piss ant main bearings. But the oils are better these days.
Wally
Well it looks like it could be money better spent.....
What pros of a dry sump system were you looking at anyway?
interesting feedback,thanks,the spitfire i have is hybrid,instead of
1300/1500, it has 2.5 six,it has billet crank,block has been
de-burred,polished etc,roller rockers(1.65-1)uprated cam,carrilo
rods,forged pistons,6-3-1-2 exhaust,will be using electric water pump,three
twin webers 45's.have done a new composite roof,rear spoiler.car is going
to be used for both road and track.dry sump is the ultimate in oil
control.although it can apparently be complex to use.the pros for me are
listed.in addition estimated extra ten hp from system.i read somewhere that
a test between the dry sump system,and windage tray,baffles etc showed that
baffled system could still not be relied on in certain extreme
situations.any feedback gratefully recieved.
ukcjm@hotmail.c
