AEM V2 intake
Home  \  Asian Imports  \  AEM V2 intake
Is the V2 intake compatable with the AEM bypass valve, or doesn't it even need it to prevent hydrolock.
Thanks.
posted by  Accord_Man
should be compatible, and i think u still need to worry bout hydrolock bc there is still a chance of gettin water in the intake. ur best bet would be to go to a distributor and ask if the bypass will fit the V2 i dont see y it wouldnt tho
posted by  CivicSi
yeah it should work
posted by  ciVicman
AEM V2 Intake Air Induction Systems utilize a dual chamber to create multiple frequency sound waves. The installation of the AEM Bypass Valve would disrupt the tuning of these systems. Therefore the bypass valve should not be used.
posted by  Import-tuner
Do they have a much higher risk of hydrolock then?
The Bypass Valve Will Not Fit The V2 Intake The Diamater Is Too Big And If Yourr Worried About Hydrolock Look Into A Comptech Ice Box
posted by  enoch1
The Risk Of Hydro Lock Is Almost The Same ,,,, The V2 Filter Sits An Inch Or 2 Higher Then V1
posted by  enoch1
