rx-7 specs
Home  \  Asian Imports  \  rx-7 specs
i want an rx-7 but have never seen one up close. are there two bucket seats in the back? or just 2 front seats? how many cylinders dose it have?
and also if you have heard of it, what do you think of the new genesis rotary motor?
posted by  Guns_10
:laughing:
posted by  GreekWarrior
If you're talking about a gen 3 rx-7 then it has 2 ROTORS, double-rotory twin-turbo. As for the seats not sure if the front are bucket but the rear isn't. And I think the genesis rotary motor is great. :mrgreen:
Quick Info MAZDA RX7
Body 2 door Liftback
Transmission 5 speed Manual
Fuel Type Turbo Petrol
Release Date 1992
Engine MAZDA RX7
Engine code 13B
Engine description Wankel rotary, twin rotors, forced induction by twin sequential turbochargers.
Capacity (cm3) 1308
Compression ratio 9.0:1
Maximum torque 294Nm (EEC) @ 5000rpm
Cylinders Rotary
Engine location Front
Block material Aluminium alloy
Engine orientation Longitudinal
Maximum power 176kW (EEC) @ 6500rpm
Induction MAZDA RX7
Induction system Twin Hitachi turbochargers, sequential electronic port fuel injection with two fuel injectors per chamber.
Forced induction type Turbocharged
Fuel system type T/PFI
Fuel tank capacity (litres) 76
Trans MAZDA RX7
5 speed man
Final drive location Rear
Final drive ratio 4.100:1
Ratio 5 0.719:1
Ratio 4 1.000:1
Ratio 3 1.391:1
Ratio 2 2.015:1
Ratio 1 3.483:1
Reverse 3.288:1
Suspension MAZDA RX7
Suspension/front description Independent, alloy double wishbones, strut type coil spring/damper units, anti-roll bar.
Suspension/rear description Independent, double wishbone, strut type coil spring/damper units, anti-roll bar. Upper strut top brace and lower toe adjustment link.
Steering MAZDA RX7
Steering description Rack and pinion, power assisted.
Turning circle - between kerbs (metres) 10.2m
Brakes MAZDA RX7
Front brake description Ventilated discs
Rear brake description Ventilated discs
Wheels MAZDA RX7
Rim material Alloy
Front tyre description 225/50 R16 92V
Rear tyre description 225/50 R16 92V
Front rim description 8.0JJx16
Rear rim description 8.0JJx16
Dimensions MAZDA RX7
Length (mm) 4295
Shoulder room - second row/rear (mm) 1100mm
Seating capacity 4
Ground clearance (mm) 135mm
Head room - second row/rear (mm) 890
Head room - front (mm) 855
Shoulder room - front (mm) 1425mm
Height (mm) 1230
Track - front (mm) 1460
Track - rear (mm) 1460
Kerb mass (kg) 1310
Wheelbase (mm) 2425
Width (mm) 1750
yes it is for a 3rd gen rx-7..
dose seating capacity-4, mean that there are 4 seats?
posted by  Guns_10
Cylinders :banghead: :banghead: :banghead: :banghead: :tard:
posted by  Oomba
Ummmm....cylinders?! RX-7s are rotary engine cars (which by the way the Germans invented THEN sold to Mazda so they could perfect it :mrgreen: ) youve got to be the only person who dosent know that :banghead:
posted by  FordFromHell351
Yeah mate 4 seats.
umm back seat???
was an option for the FB and FC. dont think its even avalible for the US spec FD....
the seats are sport seat essentially. good feel. kinda uncomfortable for long trips. leather was an option for all years.
but i warn you now, as the resident RX7 guy. they are attention whores. and unless you can work on your own car, i dont recommend it for you.
posted by  Low Impedance
no cylinders in rotary engines...
back seats...some FC's do have back seats which makes them 4-seaters
FD's...NONE!
posted by  nissanTFsx
I could of sworn i've seen an FD with back seats.....
My neighbor has an FD, no back seats.
posted by  ThirdeYe
Oh ok, i was probly thinking of an FC interior. :doh:
yea...cuz i dont think you can fit a bench in da FD :wink2:
Anything is possible for the right amount of "ching ching". :mrgreen:
are you sure there arnt back seats? how do you explaine this?
http://ad.doubleclick.net/adi/N3740.CarDomain/B1615443.5;sz=160x600;click0= http://oascentral.cardomain.com/RealMedia/ads/click_lx.ads/CarDomain.com/Me mber/MAZDA/RX7/1807179671/Right/CarDomain/THQ-Juiced_05Jun_160_Tuner/THQ-Ju iced_05Jun_160_Tuner.html/31386637346330633431393262346430?;ord=1807179671?
posted by  Guns_10
sorry, first one didnt work to great.. try this,
http://www.cardomain.com/ride/379901
posted by  Guns_10
I KNEW IT! I'm not crazy they do have back seats!!!!
