Alright!
Home  \  Asian Imports  \  Alright!
I know i said i was going to get a 240SX but i got an Integra instead and so far this is what else i got
AEM True performance cam gears
Walbro fuel pump
Stainless Cat Back N1
T3/t4
FMIC
TurboSmart Boost Controller
TurboXS wastegate and blow off valve
Apex'i turbo timer :drool:
but i still can't decide on what brand cams and springs to use. any body had luck with a certain brand, also can the stock ECU be reflashed or should i just get a plug and play system?
posted by  airmanUSN
Ive heard that Crane gets the job done pretty well on those cars.
posted by  FordFromHell351
more onfo onthe car
1996 Integra LS
5 speed
1.8l DOHC NonVTEC (B18B1)
posted by  airmanUSN
Pick Me Pick Me.
The cam gears I used on mine were AEM's, check em out, I was really impressed with them
posted by  99integra
Venom makes an excellent set of cam gears...as for springs check Toda and for a set of cams try Gude.
posted by  thunderbird1100
Was he talkin about cams or cam gears or both?
posted by  99integra
i already bought AEM cam gears like i said in my first post. i was
just asking about cams and valve springs.
posted by  airmanUSN
Toda cams are a no go i think, all i saw was vtech cams
posted by  airmanUSN
yeah, whenever it says vtec cams in magazines, does that mean that it will fit all of honda's vtec engines, including the sohc ones.
posted by  Accord_Man
try and find a Mines ecu, my brother had a good go with one on his 1jz-gte powered ma70 a while back.
posted by  HyundaGuy
with the cam's i'd suggest you get AEM's, read lots of good things about them... what are you doin' about your compression? i thought honda's came with like 10.1:1 compression's? doesn't it need to be around the 8.4:1 to run around 6psi?...
posted by  HyundaGuy
the 1.8 ls motor has lower compression
posted by  airmanUSN
