2001 Hyundai Accent
Home  \  Asian Imports  \  2001 Hyundai Accent
About a week and half ago, my check engine light came on. I took it in and it needed plugs and wires. A couple of days ago, the light came back on. Somebody asked me if i twisted the gas cap three times. I said i don't think so. they told me that was probably it.
Could not clicking it three times make the light turn on? My car is running great. Not like the first time the light came on.
My car has almost 94,000 miles on it. I have an appointment for the morning to take it in, but I am just curious of anyone thoughts.
posted by  linkinbabe21
Well its probably just some electrical problem. Nothing to worry about. I mean, its a Korean car, what do you want for nothin'? :laughing:
posted by  SlipKnoT
when you say electrical, whats the price range to fix? 100 or like 500? Personally, I think the car is running fine. I would like them to just turn it off. They are already charging me like $60 to look at it. I have had my car for three years. I know when it is not running right. But my luck, it would blow up on me driving down the interstate :ohcrap:
i used to work at a shop and we got evap check engine lights(loose gas cap) all the time. We'd charge $80 for an hour of diagnostics fees to go out spend five mins hooking up the scanner, clearing the code and twisting the gas cap while we sat around for another 45 mins. :laughing:
posted by  airmanUSN
By electrial I just mean the wiring behind your gauge cluster. It should be fairly cheap I would think....
posted by  SlipKnoT
Ok...well no offense, but I didn't really want to hear that. Although, I am not surprised. They charge like $54 an hour.
I already have gotten gas since then and the light did not come off. So could that rule out the problem?
well sometimes the ecu will reset it self after a complete drive cycle(different for every car so call your dealer) and sometimes they need to be reset manually. the shop you took it to should have written down the codes or given you a print out out what they found in order to justify new wires. if not go back and tell them you want them. if they refuse make some noise, talk to a manager, etc. Usually they will resolve the problem just to keep other customers from overhearing the situation. Anyways after you get the codes (usually a letter and three numbers like P001) post and we'll figure out where your problem could be coming from. :thumbs:
posted by  airmanUSN
Here's the deal. The first time the light came on, it was like 6:30 am. So I took it to Tires Plus because they opened at 7:30 and I didn't want to drive it very far. My car would run fine, until I took my foot off the gas. I take my car there to get oil changes anyway. They got the codes. But the price was too high for my budget. So I called another place who does my other work. I gave them the codes, what I needed. They fixed it. My car ran like new after that.
Then a few days ago, the light came back on. I turned a corner and it came on. Drivewise, it was driving like it had been after I got it fixed. I drove it all weekend and it didnt act up or anything.
So I am hoping that it's because I didn't click the gas cap three times. I always make it a point to do it, for my reasons. I didn't know that I was supposed to. When I was asked if I did it, I really don't think i did.
if you think it is the gas cap try disconnecting the battery for about an hour, this should reset the computer entirely. After that drive the car for about 45 mins to go through that drive cycle i was talking about. It's just various checkpoint your computer will go through, like GM's have a checkpoint that requires you to accel to 55mph then coast for a certain distance. Make sure you do both stop and go driving and highway driving as well. If the light comes on again you'll need to take it back to the shop, hopefully this will take care of it though. goodluck
posted by  airmanUSN
Not too long after i got my car my light came on and i took it to my mechanic. He told me it was my egr valve so i went and got it replaced. About a week later my light came back on. My car is still running jsut as well and there are no apparent problems. So im waiting for school to start back up so my friend who has autotech can run a dianogistics for free.
posted by  GonnaDie4TheGov
Hey guys. Thanks for your help. I took my car in the other day to get looked at. The code is P0133. I was told that I need a new oxygen sensor. Could it be that I didn't click the gas cap three times or whatever?
My light is still on. I was told that with labor, it would be about $120. I thought that was good because instead of charging me the $60 to just look at it, he only charged me about $30, because it only took him about a half hour.
In an earlier post, someone had mentioned unplugging my battery for an hour. After the hour, take it for a drive. I am at work and someone told me that they will disconnect for me. Do I have to drive it right away?
An O2 sensor runs about $60-$100. 90% of smaller cars have 2, one before and one after the Catalytic Converter. Don't let them charge you too much to install them..they are fairly easy to find and install. Worse come to worse Autozone.com tells you componet locations on your car. :thumbs:
Went to Autozone.com. I tried to looked under the component location. Here's what I got when I clicked on Oxygen Sensor. They already have what kindof car I have.
Sorry, no component locations were found that matched your search
Does that mean that I don't have one? I am just getting frustrated. I don't have the money to fix it. He told me that I can wait to have it fixed but I might use more gas. This is not a good time to be using more gas. :banghead:
No every car is required to have one. It has to do with emissions. Your mechanic can prob show you where they are. You car im sure gets good mpg no matter on whether thats working or not. Lucky you i have to have mine fixed by 30th of September..damn state inspections. And my car has 3 of them. :evil:
With Hyundai Accent's, you have to turn the gas cap several times even after it starts clicking. It's just a quirk with them. If you don't, your check engine light will come on. After I found that out and started doing it, I never had an issue and it's been years.
eve   07 Feb 2012 00:34
Have a 2013 Hyundai, a BRAND NEW 2013! Same type issues. When you fill it it over flows eveywhere, check engine light has gone off multiple time. Monday (because NO Hyundai dealer in Texas works on their cars on the weekend) we will be taking it in for the 3rd time in less than a month. Not why I bought a new new car! Good bye POS Hyundai, it's worth the few extra bucks for the Honda (or Toyota) piece of mind. Hyundai had one attempt to make a believer out of me and the product and service suck! Fool me once, shame on you.... and you won't get a second chance!
Not a Sucker   16 Feb 2013 22:15
