Clutchmaster HDSB Clutch
Home  \  Asian Imports  \  Clutchmaster HDSB Clutch
what kind of clutch is this? is their different versions of it? is it good?
posted by  silvia_star
Depends; it's fairly new. The HDSB is Clutch Masters' response to the popular ACT 2600 clutch. It uses a 2500 lb pressure plate and a full-face street organic disk. By achieving 2500lbs of clamping force through more modern pressure plate design, it supposedly helps reduce the chance of a "crank walk". It's supposed to handle cars making up to about 350 HP, and should be strong enough to run 11's on. I'm pretty sure it's for turbo only.
I'm not sure on the pricing but it should be pretty pricey so it all depends on your budget/wants. Hope I helped. :2cents:
posted by  Nissan_Altima
