Wonder what your ECU trouble codes mean?
Home  \  Asian Imports  \  Wonder what your ECU trouble codes mean?
1
Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98 86-98 97-98 85-91 93-97 95-98 85-98
Oxygen Sensor "A" (Primary)
defective circuit or unplugged / defective sensor
2
85-89 86-87 n/a 85-87 85-91 n/a n/a
Oxygen Sensor "B"
3
MAP Sensor (Manifold Absolute Pressure)
4
90-98 88-98 97-98 88-91 93-97 95-98 85-98
CKP Sensor (Crankshaft Position Sensor)
5
85-98 * 86-98 97-98 85-91 93-97 96-98 85-98
mechanical problem / disconnected piping
* exc 94-95
6
ECT Sensor (Engine Coolant Temperature)
7
TP Sensor (Throttle Position)
8
TDC Sensor (Top Dead Center)
9*
85-98** 86-98 97-98 85-91 93-97 95-98 85-98
CYP Sensor (Cylinder)
* not a valid code for any throttle body injection Hondas
** not a valid code for V-6 engines
10
IAT Sensor (Intake Air Temperature)
12
85-98 86-98 * n/a 85-91 * n/a 95-98 85-98
EGR Lift Sensor (Exhaust Gas Recirculation)
* not a valid code if car is not equipped with an EGR valve (some Civic models are not)
13
BARO Sensor (Atmospheric Pressure)
14
88-98 88-98 97-98 88-91 93-97 95-98 88-98
IAC Valve (Idle Air Control)
15
90-95 88-95 n/a 88-91 93-95 95 88-95
Ignition Output Signal
missing or defective ignition output signal
16
Fuel Injector System
defective circuit or unplugged / defective fuel injector
17
88-98 88-98 97-98 88-91 93-97 95-97 88-98
VSS (Vehicle Speed Sensor)
19
n/a 88-95 n/a 88-91 93-97 n/a n/a
Automatic Transmission Lock Up Control Solenoid Valve
defective circuit or unplugged / defective solenoid valve
20
90-98 88-98 97-98 88-91 93-97 95-98 92-98
Electrical Load Detector
21*
94-98 ** 92-95 n/a n/a 93-95 n/a 93-95
VTEC Solenoid Valve
* not a valid code if car does not have a VTEC engine
** not with V-6 engine
22*
94-98 92-98 n/a n/a 93-97 98 93-98`
VTEC Oil Pressure Switch
defective circuit or unplugged / defective oil pressure switch
23
98 * 96-98 n/a n/a 94-97 n/a 92-98
KS (Knock Sensor)
* not a valid code if V-6 engine
30
90-98 * n/a n/a n/a n/a 95 92-98
* Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB
* not a valid code for 1996
31
90-95 n/a n/a n/a n/a 95 92-95
Automatic Transmission Signal "B"
41
90-98 92-98 97-98 n/a 93-97 95-98 90-98
Primary Oxygen Sensor - Heater
circuit malfunction
43
90-95 92-95 n/a n/a 93-95 95 90-95
Fuel Supply System
defective or malfunctioning fuel supply system
45
96-98 96-98 97-98 n/a 96-97 96-98 96-98
System Too Lean or Too Rich
malfunction in the fuel monitoring systems
48
98 92-98 n/a n/a n/a n/a n/a
LAF Sensor (Lean Air Fuel)
54
96 96-98 97-98 n/a 96-97 n/a n/a
CKF Sensor (Crankshaft Speed Fluctuation)
58
98 * n/a n/a n/a n/a n/a n/a
TDC Sensor 2 (Top Dead Center)
* with V-6 engine only
61
Oxygen Sensor, Heated - Sensor 1 (Primary)
high voltage, low voltage, or slow response
63
Oxygen Sensor, Heated - Sensor 2 (Secondary)
65
Oxygen Sensor Heater (Secondary)
malfunctioning or defective oxygen sensor heater
67
Catalyst system Efficiency Below Threshold
malfunctioning or defective catalyst system
70
96-98 96-98 97-98 n/a n/a 96-98 96-98
malfunction with the automatic transmission controls
71
Cylinder 1 Misfire or a Random Misfire
a condition is present that is creating a cylinder misfire
72
Cylinder 2 Misfire or a Random Misfire
73
Cylinder 3 Misfire or a Random Misfire
74
Cylinder 4 Misfire or a Random Misfire
75
Cylinder 5 Misfire or a Random Misfire
* valid code for V-6 engine only
76
Cylinder 6 Misfire or a Random Misfire
80
96-98 96-98 n/a n/a n/a 96-98 96-98
insufficient flow detected
86
circuit range / performance problem
90
97-98 96-98 n/a n/a n/a 98 97-98
Evaporative Emission Control System
leak detected in the fuel tank area
91
96-98 96-98 n/a n/a n/a 98 97-98
Fuel Tank Pressure Sensor
low input
92
96-98 96-98 97-98 n/a 96-97 96-97 96-98
Now ya know :laughing:
posted by  C c C
