will the b16 g2 motor fit?
Home  \  Asian Imports  \  will the b16 g2 motor fit?
hey guys i was wonderin if the b16 g2 motor would fit on my 1991 acura integra gs without any expensive adjustments.
:D
posted by  integrakid1991
Where on God's green earth did you find a B16g2????
The only Honda B16 engines are as follows.
B16A
B16A1
B16A2
B16A3
B16B
There's no G!!!!
But to answer your question, in terms of dropping it in your bay it will fit. All B-series engines fit. Although I think your going to need a wiring harness to be able to wire your car up for VTEC as that's the only reason I see as to why you want to swap a B16 as opposed to a B18C :2cents:
posted by  elchango36
go with the b18.. but yes it will fit. all d b k will fit in your honda
posted by  vlc92189
I'm going to go out on a limb and assume he was meaning the B16 Generation 2. Which I don't think actually means anything with reference to Honda motors.
posted by  Bino
Ah, I don't know why I didn't put 2 and 2 together. :banghead:
thanks guys
how about a type-r motor?
i dont want to make any major expensive adjustments
i just kinda want it to fit in
tighten all the bolts and whatever they need to do and be done with it
and yeah i mean generation 2
im new to this so gimme a break lol
The B18 is one of the best engines out of all those IMO. :wink2:
posted by  99integra
actually nvm the b18c is too expensive
im on a tight budget
im not looking for too much horsepower since my car is pretty light anyways
this is just a starter im only 16 so i dont make a lot of money
my budget for this whole setup plus installation is about 3000
hopefully a little less but whatever
but back to my original question
will it fit fairly perfectly?
i have a b18 right now but its not a vtec and it only has 130hp at the wheels
im lookin at the b16a cuzz its got 160 and itll be a good project car for now
JDM B16A G1 Engine 5 Speed Cable Transmission
ECU (PR3)
Wiring harness OBD0
Distributor
Exhaust Manifold
Down pipe
Intake Manifold
Fuel Rail
fuel Injectors
fuel Sensors
Starter
Half Shaft/Intermediate Shaft
Alternator
A/C Compressor
Power Steering Pump
Throttle Body
it comes with all that for $1100 usdollars
plus shipping and handling
is that all i need?
you can get the gsr motor for like 2500 so invest in that.. its the b18c1 if im not mistaken.. 180 hp and like 130 torque ... here.. www.hmotorsonline.com and www.japanmotorimport.com
any help let me know
posted by  vlc92189
Why spend that money for the small hp gain? Invest it in your current engine would be more advantagous wouldn't it? Am I wrong? :2cents:
posted by  Pythias
well im also worried about fitting
i dont wana spend a bunch load of money trying to get something to fit
oh ya and will i need to get a new clutch? if so where can i find one?
thanks again guys i appreciate it
do a b20 with a type r head! :clap: good way to make some power !!
posted by  3geclipse13087
ummm stage 3 clutch would be good because it can handle a lot more HP and torque than the stock one (you'd probably burn the stock one out fast with an engine upgrade). You don't need a really powerful engine really cuz you can mod the engine later when you have the money (i.e. Port and Polish, racing valves, intake, exhaust, forged piston, titanium crank, eagle rods, turbo pushin 20PSI with the previous mods only, ect.)
posted by  Golddragoner
Stage 3 clutchs(assuming you mean a 3 plate clutch) would usually be a no-no on a street car as it'll be like an on-off switch(imagine what that'll be like in rush hour traffic:banghead: ). A decent single plate clutch is all you need on for a street Honda.
posted by  fudge
However you will need to buy some additional stuff (I assume you refer to B16A2, by the way)
posted by  fitofitin
