turbo
Home  \  Asian Imports  \  turbo
can any turbo fit any car as long as it has the right parts?
posted by  silvia_star
What sought of question is that?
You have physical and performance criteria to consider when selecting any piece of gear, let alone a turbocharger.
Silly boy, just say yes. :wink2:
To answer your very blunt and semi retarded question with a very blunt and semi retarded answer:
Yes, you could technically make any turbo FIT on any car. Whether or not the idea of mounting a garrett GT6041 to a 3 cylinder geo holds any intelligence... well thats a matter of opinion.
posted by  Zalight
:orglaugh: ROFL Good one :thumbs:
posted by  elchango36
You can put any turbo on any car, but it doesn't matter what turbo you put on, there is a limit to the amount of PSI you can run. On a stock non-turbo engine, if you go above around 5-7PSI you will start blowing out parts like no tomorrow. In order to run high PSI and get a lot more HP you have to get new, thicker gaskets that can take the pressure, get lower compression ratio pistons, and replace the rods. Also if it is a manual transmission I suggest getting a better clutch as you will burn the OEM out very fast.
(Turbo runs off of exhaust gases so you would need a header that has a connection to a turbo, unlike superchargers it can be put ALMOST anywhere in the engine bay provided you want to run that much piping to it.)
I have seen a Eagle Talon with an aftermarket turbo(not sure which one), A huge adjustable wastegate, a huge intercooler, and a 3" exhaust ALL the way back. that was nice...
posted by  Golddragoner
:blink:
posted by  Zalight
