car forums
SPECS OF ACURA rdx 2008
For full features; Go to SPECS OF ACURA rdx 2008
Acura RDX Performance & Efficiency Standard SPECS 2008
* Premium unleaded fuel 91
* Multi-point injection fuel system
* Turbo compressor
* 2,300 cc 2.3 liters in-line 4 front engine with 86.0 mm bore, 99.0 mm stroke, 8.8 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder engine code
* 18.0 gallon main premium unleaded fuel tank 15.0
* Power: 179 kW , 240 HP SAE @ 6,000 rpm; 260 ft lb , 353 Nm @ 4,500 rpm
Acura RDX Handling, Ride & Braking Standard SPECS 2008
* Electronic brake distribution
* Brake assist system
* Rear and center limited slip differentialStrut front suspension independent with stabilizer bar and coil springs, multi-link rear suspension independent with stabilizer bar and coil springs
* Spacesaver steel rim internal spare wheel
* Stability control
* Immobilizer
* Four-wheel ABS
* Four disc brakes including two ventilated discs
* Electronic traction control via ABS & engine management
Acura RDX Exterior & Aerodynamics Standard SPECS 2008
* Driver power heated body color door mirrors indicator lights, passenger power heated body color door mirrors with automatic indicator lights
* Fixed rear window with defogger and intermittent
* Projector beam lens Xenon bulb headlights
* Weights: curb weight (lbs) 3,924 and gross trailer weight braked (lbs) 1,500
* Windshield wipers with automatic intermittent wipe
* Roof spoiler
* External dimensions: overall length (inches): 180.7, overall width (inches): 73.6, overall height (inches): 65.2, ground clearance (inches): 6.2, wheelbase (inches): 104.3, front track (inches): 61.9, rear track (inches): 62.6 and curb to curb turning circle (feet): 39.2
* Luxury trim leather on gearknob, leather on doors and alloy look on dashboard
* Pearl paintBody color front and rear bumpers
* Front fog lights
* Day time running lights
* Glass electric front sunroof
Acura RDX Interior Standard SPECS 2008
* Peripheral anti-theft protection
* Cargo capacity: rear seat down (cu ft): 60.6 and all seats in place (cu ft): 27.8
* Clock
* Computer with average fuel consumption and instantaneous fuel consumption
* Front seats and rear seats cup holders fixed
* Full dashboard console with open storage box, full floor console with covered storage box, partial overhead console
* Delayed/fade courtesy lights
* Cruise control
* Driver front airbag with multi-stage deployment, passenger front airbag with occupant sensors and multi-stage deployment
* Front seat center armrest
* 3-point reel rear seat belts on driver side, passenger side and center side
* Rear seat center armrest
* Three asymmetrical split bench front facing rear seats with zero adjustments
* Seating: five seats
* Service interval indicator
* Front side airbag with occupant sensors
* Seven speaker(s)
* Garage door opener
* Manufacturer's own RDS audio system with satellite, Disc Autochanger and six-disc remote changer CD player reads MP3
* Automatic drive indicator on dashboard
* Cargo area cover/rear parcel shelf
* Cargo area light
* Front reading lights
* Door ajar warning
* Door pockets/bins for driver seat, passenger seat and rear seats
* External temperature
* Floor mats
* Front and rear side curtain airbag
* Front seat back storage
* Leather seat upholstery with additional leather
* Two height adjustable active head restraints on front seats, three height adjustable head restraints on rear seats
* Low tire pressure indicator
* Tachometer
* 12v power outlet: front and 2
* Front power windows with two one-touch, front and rear power windows
* Leather covered multi-function steering wheel with tilt adjustment and telescopic adjustment
* Illuminated driver and passenger vanity mirror
* Ventilation system with micro filter
* Vehicle speed proportional power stering
* Headlight control with time delay switch-off
* Illuminated entry system
* Remote power locks
* Air conditioning with climate control 2
* Roof antenna
* Sports heated electrically adjustable driver seat with height adjustment, lumbar adjustment, five adjustments and tilt adjustment, sports heated passenger seat
* Height adjustable 3-point reel front seat belts on driver seat and passenger seat with pre-tensioners
* Internal dimensions: front headroom (inches): 38.7, rear headroom (inches): 38.3, front hip room (inches): 54.4, rear hip room (inches): 53.0, front leg room (inches): 41.8, rear leg room (inches): 37.7, front shoulder room (inches): 58.2 and rear shoulder room (inches): 56.3
* Rear view mirror
* Steering wheel mounted remote audio controls
* Remote fuel filler door release
* Coming home device
FROM posted by  BOZZ CARS
It would apear what I said here (http://www.car-forums.com/talk/showthread.php?t=28909) was a clear indication of things to come...:banghead:
If you do intend to stay, which I very much doubt you do, then I strongly suggest you read our forum rules! Please use the PM system if you have any questions.
And you posted this in the European section....:banghead: posted by  Cliffy
Slogan T-shirts from $15
itself Slogan T-shirts
SELL YOUR CAR
@ CF Classifieds
