Brake torquing good or bad?
Home  \  Asian Imports  \  Brake torquing good or bad?
Hi i was wondering if brake torquing is bad way to burnout. I am talking about an automatic and front wheel drive viechle. Brake torquing is like on a manual when you rev it up and dump the clutch. But on an automatic front wheel drive car its when you press brake pretty hard but not all the way and press gas to like 2000 rpm aroud there. When your there you will let go of the brake and then the car will do a burnout. I know this isint good for the car but is it worse than going on the N (neutral) and then into drive? Also any other ideas about how to do a burnout with a auto with front wheel drive.
posted by  Kris
