Crx Hf To Zc Has Anyone Done This
Home  \  Asian Imports  \  Crx Hf To Zc Has Anyone Done This
I AM IN THE PROCESS AND HAVE A COUPLE ?'S . IF SOMEONE HAS DONE IT LET ME KNOW :screwy: :banghead:
posted by  GUS1
what are you asking? swap a zc motor?
posted by  CarEXPERT
I've seen it done, It's a relatively simple process. I suggest using Hasport motor mounts though.
posted by  thunderbird1100
I Have The Motor In And Wired But I Am Getting A Code 8 Flashing Wich Is A Tdc Sensor Fault So Basicaly Im Getting No Spark
posted by  GUS1
The ZC should be a fairly simple swap since that is the engine that came in CRXs in japan.
Did you have a professional do the wap or did you do it yourself?
posted by  Zalight
