r33 engine swap
Home  \  Asian Imports  \  r33 engine swap
hey is it possible to put a rb26dett in to a gtst r33? also would a stock supra be better to buy then a stock gtst r33 as in which one will be cheaper to modify and which one would perform better?
posted by  azn2nv
yes you can drop a rb26 in a r33. Stock MkIV turbo supra are a lot faster then a r33 GTSt.
Supra are pretty heavy, so you need a lot of HP to get them going. 800hp from a Supra is about the same as 500hp from a silvia. (performance wise)
Between the 2 motors, 2jz and Rb26. The Rb26 will cost u more, but you will get better hp.
posted by  57ock
