amp questions
Home  \  Asian Imports  \  amp questions
how do you bridge your amps? does audiobahn make good amps? what are good amps? what are those amp capaciters? can you use just one amp for 2 subs? what are crossovers?
posted by  silvia_star
It shows you exactly how in the manual, but you just only use two of the four outputs on the amp (assuming it's a two channel amp). In other words, the outer most negative and outer most positive.
Absolutely not, They overrate their amps extremely badly. Hifonics, Alpine, Kicker and Orion are much much much better amp makers.
They store power in them so when you hit real hard bass it doesn't suck your battery down and your headlights shouldnt dim (as much).
Sure can.
They in basic tell what frequencies above and below to send to where.
posted by  thunderbird1100
