DodgeRida67
My message is too long for a PM (n fact, it's too long for 3 of them,
damnit!
Ok, here's what I'd tell them: there are guys in the thread that run KBs
with no problems, and guys that hate them. The guys that HAVE them have
more proof than the guys who simply SAY they will break. Simply put, at
room temps, the forged are stronger than the hypers, but at elevated temps,
it's the other way around. Ask the guys sayig the KBs are "glass pistons"
for some proof to back up their claims, OTHER than math.
The most common piston found in production car engines, is constructed from
a Eutectic alloy. The term Eutectic mean that the piston allow contains
around 12.5% silicon. This is just about the point of total dissolved
silicon saturation. With older piston designs which have conventional ring
lands, there is little need to have any more than this simple, reliable
material which has served the industry so well for so long. In fact all the
worldwide passenger car engine manufactures we know of still use the 12.5
per cent alloy.
Hypereutectic alloy is pretty damn similar, but has a much higher degree of
silicon in its makeup, something around the 16-18 per cent mark. What this
actually achieves in the piston-manufacturing process is a high degree of
free (undissolved) silicon in the end piston. The silicon/aluminium ration
affect the metal's character. The higher silicon content in the
Hypereutectic alloy lends itself to improved scuff resistance and,
importantly, a relatively low expansion rate. The Hypereutectic alloy not
only expands 15% less than a forged alloy, it insulates the skirts from
combustion chamber heat. If the skirt stays cool piston expansion is
drastically reduced. Running close clearances is beneficial to piston ring
seal and ring life. A small short term HP improvement can be had by running
additional piston clearance because friction is reduced.
With Hypereutectic pistons, the primary reason for having all of this free
silicon is to reduce piston ring groove wear. This allows piston designers
to move the top compression ring much farther up the side of the piston
(where combustion temperatures are much hotter), and run much smaller,
thinner piston ring lands (the metal section separating the ring grooves).
Their main advantages being reduced chance of ring/grove welding and
reduced piston ring grove wear. If higher piston strength is needed, then
generally, a piston manufacturer will add more copper and nickel to the
alloy to gain extra high temperature strength.
The only real disadvantage of a cast piston (in high output situations) is
in the case of a piston failure, a cast items is more likely to shatter and
damage the engine, as a whole, more than a forged piston. So, as i said, if
you drop a valve or a bolt, a forged piston won't try to destroy the rest
of the engine (but the engine's still ****ed..)
A big advantage with forged pistons is they generally result in a more
ductile material, with the effect being the piston can take a higher level
of detonation before failing. As far as I am concerned, this is not such a
huge bonus as you engine should be tuned not to detonate in the first
place. In extremely high rpm/high horsepower applications, the great
strength of the forged piston can add reliability, with most builders
recommending they be used once power levels rise past about 90hp per litre
of engine capacity.
Silvolite actually likes to use hyper pistons in nitrous engines, as the
material withstands heat and detonation better than forgings (though a
poorly set up nitrous system can melt ANY piston). Designing a maximum
performance nitrous engine is more of an exercise in heat management than
it is in engine building.
Now, the guys over there are right about the stock forged rods. They are
plenty strong, with some good ARP rod bolts.
I figured out the part about the rods saturday. I decided to use them that
day, and ordered a set of the strongest rod bolts ARP had. Looks like I'm
not too hard headed. :mrgreen:
About the pistons, your thoughts are pretty much my thoughts. I really
believe in these pistons, and in this setup.
When you said "Silvolite actually likes to use hyper pistons in nitrous
engines, as the material withstands heat and detonation better than
forgings (though a poorly set up nitrous system can melt ANY piston). " and
"As far as I am concerned, this is not such a huge bonus as you engine
should be tuned not to detonate in the first place." Hey, amen to that.
I'll copy and paste your thoughts on there and see what they have to say
about it. You went an extra step to help me out, I greatly appreciate it.
