Double Turbocharger + Honda Civic
I scratched the idea of getting a toyota avalon, and decided to get a Honda
Civic. First I have a couple questions:
1. Is their such thin as a double turbocharger? And if so, can you get a
decent one for around $1000-$2500? (Cheaper is better :p, as long as its
decent)
2. What double turbochargers are compatible with a honda civic/how do you
tell if one is compatible with a certain car?
3. How much horsepower can a double turbocharger add to a car?
4. What makes a double turbocharger (if it exist, google turned up some
results but no actual places to buy one from so im a little skeptical),
versus a regular turbocharger. And whats the difference between a
turbocharger and a supercharger?
Thanks a lot in advance to anyone who answers and yes i've tried googling
all of this.
im not that good but ill give it a shot.
just the basic and simple things,
superchargers give you low end power, meaning you will be able to
accelerate off the line much quicker
turbochargers are the same but only at higher revs, so at the start it will
lag a bit.
depending on what you want for your car, both are practically the same. i
read off a magazine that this guy in an evo put both on his
car(supercharger and turbo) dunno how he did it though
*edit*: dunno about this but i think a double turbo is just 2 turbos joined
by 1 pipe leading to the actuall engine. ill let the more experienced guys
handle this now...
that helps, yes i have read the howstuffworks article on turbochargers. It
says that one turbocharger can increase horsepower between 30-40% since
their is some error in it. So that brings the civic up from 115 to 155.25
horsepower, using the mean of the %'s given by howstuff works. Now if I
have two double chargers will that take that second number (155.25
horsepower), and increase that by %30-%40 giving an average of approximatly
210 horsepower? OR will it simply increase the stock Horsepower of the car
from %60-%80 (average being %70 obviously), giving me around 195
horsepower?
Also, what are some other things to increase my horsepower on the civic?
And what are two turbocharges (which is a double turbocharger i guess),
that will be compatible with my honda civic in the price range of about
$1250, or if you could simply tell me how to decide wether or not a turbo
charger is compatible, and then gimme a site where I can buy them from.
$1250, i dont think that might be enough for a turbo setup in a civic since they are NA plus i live in new zealand so i cant really help you too much
i can go up to $2000, i wouldnt want to but i can.
Looks like the answer is YEP!
http://www.lateral-g.net/sandlin/sandtubing3.jpg
http://www.lateral-g.net/sandlin/sandtubing2.jpg
http://www.turbocalculator.com/turbo-works.html
http://www.turbo-kits.com/civic_turbo_kits.html
here are some sites to help with your findings. the first one tells you how
it they work and the secound one is kits for honda civics and some prices.
But it is not called a double turbo charger it is called twine turbos.
Is that because they're held together with rope?
no god you suck. they are called that because they are the same turbo but they are on two diffrent sides of the engine. but turn on at the same time and increases hp by about 70% almost.
The same turbo on two different sides of the engine. How do they do that, cut a turbo down the middle? Read your post again, get out a thesaurus (do you even know what that is?) and with almost no effort, something you're obviously good at, you'll understand where the rope reference came from.
wow your dumb. did you not read i said they are meaning two. next time know what your talking about. :2cents:
Not all TT setups have the turbos on opposite sides of the engine. You're
generalising, or atleast talking about a general application
http://www2.odn.ne.jp/cdr48770/Gtreng.jpg
Nope. Read your post. You very specifically said...
It doesn't say anything about two. Words mean things Zippy (as in
pinhead).
same as in the same type thats why it is twine meaning two that look the same. now you know.
It looks like we have a new winner in the "Stupidest Person to Ever Join a
Forum" contest. :banghead:
Try reading this if the words aren't too big for you;
http://www.onelook.com/?w=twine&ls=a
my bad i meant to say twin i didnt mean to add the e.
Im looking to get this turbo kit for my car:
br />
Civic Extreme Turbo Kit For 01 and up Civics:
- Garret t25 turbo w/ Wastegate
- Cast Exhaust Manifold
- Chrome Heat Shield
- Downpipe w/ Gasket
- Map Unit (Black BOx)
- TSI Blow Off Valve (BOV)
- TSI High Flow Front-Mount Intercooler
- Polished Aluminum Intercooler Piping
- SS Btaided Lines for Water Cooling
- SS Braided lines for Oiling
- Return Hose and Fittings for Oil to Pan
- All Hoses & Clamps
- All Necessary Hardware & Fittings
- Generic Install Instructions
Fule System 1:
- 2 Injectors & Interface Block
- TSI Injection Control Unit w/ Turbo Timer
- Injector Control System Settings
Fuel System 2:
- APEXi V-AFC II
- APEXi Turbo Timer
- Boost Gauge
br />
1. Which Fuel System would be better for a stock car, not worrying about
lag and simply wanting the most possible horsepower.
2. What does all that crud mean?
3. The site says a %56 Increase in horsepower, and that its safe to use on
a stock engine. But then for turbo efficency it says 325+ HP. So will I be
getting a %56 increase in HP or 325+ HP?
4. What are some other parts I could buy that would work with my stock
CIVIC to increase Horse power?
*Bump*
it all sounds good. but the best fuel system would be the first one and i would add the boost gadge as will to that. can you tell us how much that one is and what site you got it from that could help in finding a better kit for you. as of other sites i would have to look around. ill get back to you on it.
okay....all of you should go to the bookstore and get the book called
"turbocharging" by Corky Bell.
and VWHobo is just being an ass. its like, what he does. so deal.
that said lets see if we can clear some stuff up. there are two instances
of more than one turbocharger exisiting on one motor. These are "twin"
turbos and "sequential".twin being a general case we will look at. you can
use more, buit there is no preformance advantage. First, the twin turbo
setup comes in two ways. one is on the V blocks. this is because you cant
have a header on one side which just leads straight out, then the other
side having a turbocharger setup. the reason is in the basic engine
operation. you want the exhaust flow from both sides to be equal. you can
run both sides into one turbo but not one side into a turbo and the
otherside into just the exhaust piping.
on inline motors twin turbos really are not for any preformance value in
comparison to a sinlge setup. you are simply dividing the exhaust energy
between the two turbos. this means you could run two smaller compressors
for each but you do restrict the exhaust gases escape even more. really
this should only be usable for motors with inline 6's and larger.
now for sequential setups. this is a rare setup and only widly produced in
supras (gen 4) and 3rd gen Rx7's. now the setups are finky beyond all
belief, require numerous vacuum controls and electric controls to alter the
valving. the dealerships tend to be unable to fix problems in these
vechiles. that is why people with just go with a single turbo instead. dont
even try to make your own sequential system. how it works is that there is
a smaller turbo and a larger turbo. exhaust gases directed through the
small army of controls. what is does is spool the smaller turbo at the
lower rpms then as that trubo maxes out the other turbo reaches boost and
takes over for the rest of the rpm. There is a change is boost during the
crossover. on the RX7 the boost would go 10-8-10. the dip is from the turbo
changeover.
So its not possible to have a single turbo on a V engine right?
no, it is but both exhaust manifolds MUST merge into one then into the turbo.
Yea But V engines have exhaust manifolds on the left side and on the right, the middle is the intake manifold. So usually its not possible. What cars are there that have V enigne with a single turbo? zx?
Saab run their GT17's on a bank of three pots rather than all six.
its callled "custom" but 99% of people go with the standard twin turbo setup to achieve a nicer, well fitted and more relieble turbocharged motor.
a small correction. twin turbos that are run at the same time are actually
called parallel twin turbos. there are also 2 different types of parallel
twins.
one example is that both are run by their respective banks (this is on V's
or Flats) or just get assigned certain cylinders (mostly for inlines since
its only one head).
the other type is the one i keep forgetting the name of (ill remember
eventually). anyhow, the second type is one that works a bit confusing but
its very simple once u actually understand it. this is mainly done on
engines with 2 heads. the turbo on one bank of cylinders feeds the
opposite side of the engine, and vice versa. so pretty much, the left side
turbo feeds the right side cylinders, while the right side turbo feeds the
left side cylinders. this is pretty much done to keep as much of an even
distribution as possible. i have never heard of an inline doing this, but
correct me if there are any inlines with this set up.
other than that, the other set up would be the sequential twin turbos which
has already been explained by low impedance.
There is a 350z VQ35DET that is single turbo..how does that work cause doesnt the exhaust manifold come out of the left head and the other from theright head.
Well VWHobo I find myself agreeing with you more and more often. It seems that as ignorant as I am, at least I usually try to keep it to myself, unless asking a question. And I hope for the sake of America that people like sniper go back to school and learn how to spell simple words like 'twin' instead of 'twine' and 'gauge' instead of gadge.
i wish i could post the intro video of inspector gadget with the theme song and all just about now.........
ok will :fu: you all but i am in high school and i didnt mean to type that so dont be a bunch of dicks and besides me and hobo already talked about it so dont bring somthing old back up dumb ass. :2cents:
ill do this to the best of my ability in order:
1.To ur first question the best bet would be the the fuel system 1 option
but running a turbo means ur gunna need a boost gauge.
2.Next all that crud is telling you wat ur buying the T25 is a type of
turbo personally for a civic i would suggest the T3/T4 hybrid. Turbonetics
sells a good kit for that turbo or u can look for DRAG.
3.The 56% increase means u should add 56% of the hp ur engine already
produces however from all turbos ive seen on a civc the horse power gain is
usually between 90hp and 100hp at the flywheel. the 325+ hp rating is so u
know how hard to push ur turbo. Their saying that ur turbo is good for
runing 325 hp and over. the T3/T4 i suggest is rated at 350+ and it runs
around 6.5psi rather than the 5.3 ive seen from the T25s
4.Depending on what engine u have in ur civic would help me decipher what
other bolt-on mods to run. In my car with the B16A2 i have DOHC VTEC
therefore quick bolt-ons arent much of a help for me. However since i
doubt u have an Si i would suggest the AEM V2 CAS, high flow headers, and a
catback exhaust.
Any other questions feel free to ask me i love helping out a Honda Tuner
b/c to be honest with you there arent many of us around my parts
Holy shit Hobo, you care to explain what that exactly is? I looks interesting..
Looks like 4 turbos to me... correct?
Not familiar with the car or the engine though ... hobo?
It appears to be a 57 Chevy. You can tell by the valve covers and intake
heads that its a newer Chevy V8 engine. Probably an LT1 or LS1. Anywhos,
the question is that I only visibly see 4 structures that resemble turbos.
The confusion entials is where I see 8 exahust header tubes that lead to 8
different turbo exhaust inlets. If there were only 4 turbos then there
would more than likley be 2 header tubes to each turbo. If I'm not
mistaken, I can visibly see 8 different turbos.
The picture is confusing as there is alot that is'nt visible. Again, I
think Hobo may be able to clear this one up.
