running on fumes? mpg mod idea
ok well, I drive a 1994 jeep cherokee 4wd, automatic, with the HO 4.0l I6,
and I'm lucky to get 18 miles to the gallon. From what I understand,
engines burn gasoline vapors, or an atomized fuel/air mixture, the gasoline
vapors (fumes) are the most volatile, and bigger drops of gas do not burn
as efficiently.
I'm thinking about making an intake/induction system, where the injectors
would spray into a "mixing box" which would have a drain going back to the
gas tank, a vacuum line with a needle valve to the intake manifold, a
bigger hose to the throttle body, and an intake with a filter, plus flame
arrestors everywhere to minimize the risk of explosion. So the gas that is
evaporated, or finely atomized would get sucked into the engine, but bigger
drops of gas would fall to the bottom and drain back into the tank. I think
it will work, but the engine will probably run hot, because there will be
no liquid gas to cool the cylinders, so maybe water/ethanol, or steam
injection can fix that. shell engineers in the late 50's did something
similar and made a car that got over 350 miles per gallon (article here:
http://www.treehugger.com/files/2008/02/souped_down_old.php) they heated
the fuel so it evaporated into a lean vapor, plus a ton of other mods, but
for 350+ mpg it doesn't look very special.
thoughts? comments? all are welcome. This is just an idea, and I think the
jeep engine may be too complex for this without modifying a lot more than I
would like to, If I'm going to actually build something, it will likely be
on something that isn't my daily driver lol.
idea #2 was to kill 2 out of 6 cylinders to cut fuel consumption by 1/3
http://car-forums.com/talk/showpost.php?p=268372&postcount=7
post #9 was a little revision on the cylinder kill idea
http://car-forums.com/talk/showpost.php?p=268376&postcount=9
post #10 was a bit of revision on the original vapor box idea, included
thoughts of adding EGR
http://car-forums.com/talk/showpost.php?p=268393&postcount=10
I don't know where in the engine the fuel is injected, but if it is
throttle body injected it might work. Multipoint fuel injected might be a
little more difficult. I think it would be easiest on a carbed engine.
Biggest problem would be to control the air:fuel ratio. Temperature changes
are going to effect the rate of atomization of the fuel, so will the car
stall at high RPM on a cold day? will you need to heat this "mixing box" to
be able to get a usable amount of vapor in the air?
Don't forget the other modifications that where done. the deletion of the
transmission, the reduction of drag, the reduction of weight, and the
reduction of rolling resistance. Never mind that holding a steady 30 MPH is
nowhere near typical driving conditions.
I think you are right about a carb'd engine being easiest to convert, and I
would expect the a/f ratio with something like this would be leaner, but I
think efficiency would be better. Other people have made carburetor
replacing fuel vaporizers, some work like bongs
(http://www.youtube.com/watch?v=uxnmH3sEXts) others use ultrasonic pulses
to break up gasoline into mist, works like a cool mist humidifier. the jeep
engine is port injected, one injector per cylinder, for my idea I would
probably heat the fuel on a coolant line, and set up the intake to pull air
from around the exhaust manifold. Gasoline produces vapor even at low
temperatures, as low as -40c, but you're right, heat does help with
evaporation. the idea is to get an even burnable mixture of gasoline vapors
into the engine, instead of spraying atomized gasoline directly into the
engine, so it can use less fuel, at the cost of power.
I found a video about the 1959 shell car
http://www.youtube.com/watch#!v=II1_Vg8dP64&feature=related
http://www.youtube.com/watch?v=Fz6XTJKagOE
As you can see, the biggest problem will still be regulating the mixture
entering the cylinders. I would imagine the gas:air ratio in the "mixing
box" is going to vary depending on the temperature, engine RPM, atmospheric
pressure, type of/additives in the fuel (E10/E85/invigorate/nitrogen), etc.
Just not sure how you are going to regulate it, unless you use some complex
computer controls.
yeah regulating the mix would be tricky on a hand made system, but hey, even the 2 stroke motor in that video is running on it! as long as it runs, and is enough to run the a/c and drive, plus get good gas mileage and not melt the pistons, I would be happy. this guy put something similar on his truck, it isn't put together very well, but it runs! http://www.youtube.com/watch#!v=jCs4lLkIVCY&feature=related
Driving a 1994 Jeep with a 4.0 6cylinder engine is asking for it to go
through petrol quickly. Heavy, unaerodynamically efficient, an engine that
is probably getting to the stage where its worn and a drivetrain which
loses considerable power compared to a FWD car. You've done well to get
18mpg (USA mpg is different to rest of world as your gallon is smaller).
There's a huge scope for improvement before you even start on the trick
inlet system but that depends on how far you want to go.
You may want to read up on direct injection engines as Porsche has used it
to great effect in their LMP2 RS Spyders where they can get same horsepower
and better fuel consumption. The difference is very noticeable but
requires high level of engineering.
I have another idea, which may be able to cut my fuel consumption by 1/3rd,
basically I would remove the rocker arms, pushrods, and lifters off of two
cylinders, I would be sure these cylinders were 180 degrees from one
another, so while one is at TDC the other is at BDC, then I would remove
the spark plugs from the two cylinders, and connect a braided steel line
from one spark plug hole to the other, and disconnect the fuel injectors
for the two cylinders.
the valves would stay closed so it wouldn't disturb vacuum or exhaust,
there would be no compression in them because the air would exchange
between the cylinders, and I would still have 4 running cylinders totaling
about 2.7l of displacement. sure I would lose power, but I don't ever
really stomp on it anyway, and it would be easily reversible.
thoughts on that one? :hi:
remember you have a 4-cycle engine, you would want both cylinders at TDC,
which would cause your braided line idea to no longer be valid, and your
power output will still be uneven. Also, it will totally screw up your
computer and that might well neglect any efficiency you may have gained.
Same problem with running on fumes, sure you could get it to run, but any
deviation from your ideal air:fuel ratio is going to negate any gain in
efficiency, and possibly destroy your engine. Also, expecting it to be able
to run the AC and make it up a hill is quite a demand.
If you could make it so that the "mixing box" contained only gasoline in
the gaseous state, you could use something similar to a propane carburetor
to regulate the fuel ratio. The only difficulty would be that a gas is more
sensitive to changes in temperature, atmospheric pressure, elevation, etc.
so it may be necessary to adjust the carburetor depending on the weather
for optimum efficiency.
No matter what you do, with a computer controlled engine, unless you
reprogram the engine for the new system, it is bound to give you a
headache. I think you would be better off trying your ideas on a scrap
lawnmower first, then trying them on an old beater car with a carbed engine
without computer controls.
wouldn't you be better off trading your jeep in for a little subcompact?
you wouldn't want to try any of this stuff on your daily driver and get
stuck stranded without a vehicle anyway, so why not get a more efficient
vehicle for everyday use? not sure how far you commute or what you have to
carry, but there are other options; walk, bike, moped, motorbike, carpool,
mass transit, etc. other stuff to try before you go ripping your engine
apart.
did you try stuff like reducing as much weight as possible, hypermiling,
etc?
yeah a new car would be great, I would love to get a 1996 or newer geo
metro 3 cyl with manual transmission, it's my dream car.
I thought about it today, and thought instead of trying to tie the
cylinders up with a braided line, maybe just get a tube that screws into
the spark plug hole and goes to a small filter, and possibly remove the
exhaust valve to lessen the turbulence threw the small spark plug hole.
I would love a smaller engine, I may be able to get my hands on a lawn
mower engine to make an air conditioner/ generator, or maybe a leaf blower
engine to set it up on a bike, that would be neat. I need to get my hands
on a paycheck first though :doh:
So where is vwhobo anyway? with his vast knowledge I'm sure he could add
something useful to this thread.
I've been thinking about this idea, the vapor/fume intake especially, I
want it to pass emissions tests, and the emission I'm worried about is NOX
because it will be running a lean mixture. I was thinking of incorporating
an EGR system to lower combustion temperature, and reduce NOX emission, I
haven't seen a home made system with egr, but I think that if I build
something I will incorporate it. I was also thinking of having the system
computer controlled, because tuning air bleeds, and egr valves while
driving is a little bit much for the year 2010, so I was thinking about
using an O2 sensor as an input, for the computer to determine what to do,
well the o2 is inevitably going to be high because of the lean mixture (not
enough gas to consume all of the air) that is where egr will come in and
reburn some of the exhaust, so it will dilute the intake air with enough
exhaust so that the final end product has a normal or lower o2 reading,
hopefully normal nox emission, low co2 and hc. I think if I can work the
egr, air bleed, and vapor box to burn clean enough I can reduce or
eliminate the need for a catalytic converter or post combustion, but we'll
just have to see.
vwhobo is right here. But you don't want to hear what I have to say. Your
idea is so bad on so many levels that I don't have the time or energy to
address them all. I'll just briefly touch on the last post.
You won't pass the emissions test because even if you got past the sniffer,
you wouldn't make it by the visual. Especially without a cat. If any of
your ideas would actually work in the real world, why wouldn't car
manufacturers, not even one, who spend billions on designing new models and
engines already be using those same ideas.
The reason is that they don't work. Think about it.
ahh there you are! thanks for stopping by, No no, I do want to hear what
you have to say, your opinion is important, I consider you an expert.
I guess your right then, but there is one independent company with a car
that uses similar technology as to what I'm thinking of
(http://www.fuelvaporcar.com/html/the_car.html) and I refuse to believe
that gasoline engines can't be improved upon, so I will do as you say and
think about it, I think eventually I'll come up with something good. There
are some obvious things to work out and develop in something like this, but
I think it's possible, and these are just ideas.
as of now, I'm kind of stuck on this gasoline vapor idea, several people
have proven it works on generators, the car in the above website, etc and
have shown a considerable reduction in fuel consumption versus a carburetor
or fuel injection. There is only so much energy in a gallon of gas, but I
believe the potential energy can be had most efficiently by burning vapors
rather than burning the liquid fuel itself.
maybe instead of trying to evaporate the gasoline, I should focus on better
atomization of the gasoline. I am thinking maybe a higher fuel pressure,
and a smaller injector nozzle, or the same fuel pressure with an updated
style of injector which has several smaller outlets, instead of one larger
one, to get a finer spray of gasoline. Then the pulse width of the
injectors could be tuned, and no further modifications would be required,
but combustion efficiency would be increased due to the smaller sized
gasoline drops. Even at low rpm I think a finer atomized fuel mix could
increase power output, and fuel economy, while reducing emissions.
thoughts?
I think you're grabbing at straws, you would spend how much $$ for an
increase of say 0.5 mpg? You would be better off getting a motor bike that
gets 3 times your MPG , have reliable transportation, a backup vehicle to
use in bad weather/hauling large objects, and only have to spend several
thousand dollars max. Could easily pay for itself in 15k miles.
I still don't think it is wise to go tearing apart your daily driver for
such little improvement. Would be cool for the theory, to see what you
could get it to do, but not the thing to try to do to save money when you
are on a tight budget.
I concur for all of the reasons stated above.
Even if you did a substantial amount of modifying/re-engineering the best
you could hope for is a 5-10% improvement, which would translate into
.9-1.8 mpg (based on your figure in the OP). You could gain that amount
essentially for free.
How? First, make sure that all of your maintenance items are 100% up to
date and done right. This includes fluid types and levels as well as
underhood items such as ignition components and filters. None of this is
actually free, but because you're supposed to be doing it anyway you can't
include the cost. Run 5w30 in the engine and synthetics in the
transmission, transfer case and differentials.
Second, don't do the "warm up" thing. Get in, start it and drive. No
matter what wives tales you've heard it's actually better for the engine
and trans, as long as you don't flog it.
Third, don't flog it.
Fourth, don't use drive thrus, and if you're too lazy to get out and go
inside, shut it off while waiting.
Fifth, crank up the tire pressures to the maximum listed on the
sidewall.
Sixth, drop the driveshaft to the front differential.
Or you can do what my son did. He got tired of feeding his Dodge Ram at
$60-$75 per fill up. He couldn't ride his Honda 919 to work most days
because he either had to drop off or pick up his son from daycare or
Grandpa. So we scored him complete but neglected '95 Ford Aspire (Kia) for
$300.
He added another $500 worth of parts and tires, a couple of evenings in the
shop and then a weekend of detailing. He now has a commuter car that is
clean, relatively comfortable for two adults, a kid and a dog and stone
reliable. The best part is it does right around 40 mpg depending on if the
A/C is in use or not. Even including the cost of registration and
insurance, he amortized the cost in less than six months by leaving the
truck parked most of the time.
I guess the moral to that story is the best way to get better fuel economy
might be to start with an economy car. Think about it.
yeah, I'm just thinking out loud with these idea's, and probably will not
tear into the jeep too much (because its my dads car), your advice is very
practical, and I am thinking about getting a smaller car, when I can.
all good advice from the master as well, 1-4 check, I need to check my tire
pressure, and I thought about removing the front drive shaft the last time
I was under it, but the chain in the transfer case is broken and gone
already so it isn't connected to anything there, so I thought it wouldn't
give very much improvement. Might more benefit be made by removing the ring
gear on the front axle? Not that I'm going to go that far with it, because
I want 4wd in the future, just a thought. I'll check out the haynes repair
manual, if the front driveshaft isn't very difficult to remove, I will go
ahead and take it out to see if it helps.
Thanks for the input guys, keep it coming.
Going on about the last idea I had about changing up the injectors, I
thought last night, about modifying the signal from the o2 sensor, to make
the ECU think the engine is running rich, so it will try to correct it by
leaning out the mixture, and less gas goes into the engine = better
mileage. Or to do the same kind of thing, I could partially cover the o2
sensor with foil, so less exhaust can come in contact with the sensor, and
it would give a lower than normal o2 reading (it would think it is running
rich) so it would correct by running leaner. Or what may happen is the ecu
would think the sensor is now faulty and run on predetermined
specifications for fuel delivery :laughing:, I would hope for a more
interesting outcome then that though. If it works, I wouldn't have to
modify anything else, the ecu would do the work for me and run the engine
leaner than normal... after that, other mods can be made to keep it running
happy whilst being leaner.
Although stuff like these are best left to the professionals who have the
budget and resources to test out new technologies, I still do admire your
willingness to try out different things. Even if it won't work or give
very little improvements at least you're learning more from this and who
knows where this leads you in the future.
Dunno about the US but in europe we have the choice of converting our cars
to liquid petroleum gas. It may not give as much range as unleaded petrol
or diesel but it is half the price and has a high octane rating which leads
to higher compression ratio or turbo boost to offset this disadvantage.
Ford has used it to very good effect in the British touring car
championship this year. Main problem is few petrol stations sell them so
journeys need to be planned carefully to not come up short.
Even though I'm not a fan of hybrid cars, you can't deny their potential.
I've been shown the latest performance hybrid systems as used on Lemans
racers at Zytek and the KERS system which they develop for Mclaren F1. It
is a very impressive albeit highly complex piece of engineering and the
results show with a hybrid Porsche almost winning the Nurburgring 24hours
outright this year.
Thanks fudge, I consider myself a thinker, I want to make cars better, more
efficient, and cleaner, I hope one day I can show something for my
effort.
I've heard of LPG conversion, but am unsure of the limitations or smog
legality of it here in the states. I would like to try all kinds of fuels,
just as long as they can be clean burning, and easy to produce or are
readily available. I will do some research on LPG and see what I come up
with.
Yeah I think hybrids are great, and some of the hybrid technology that has
been coming out is impressive, like the KERS you mentioned. I would like to
see more races limit the amount of fuel allowed, like a 2 gallon 200 mile
race, it may start out boring and slow, but with enough engineering and
developement, it could start a competitive and challenging race, which
would likely have an impact on new cars for the street. Unlike nascar,
where the cars get 6 or 7 miles per gallon, and are running on 50+ year old
engine technology.
vwhobo! Thanks for the advice on removing the front drive shaft, you definitely have the right idea, I've been having a noise issue, a ticking noise which would happen while decelerating, braking, going into dips, I suspected it was the front drive shaft because I didn't feel anything in the pedal, and it ticked with the speed of the drive train. so I marked the relationships with some paint, and removed it, then test drove and immediately noticed it was faster, then hit the brakes and the noise was gone! problem solved! after inspecting the drive shaft I wasn't surprised, it didn't feel smooth, was very dirty, and the joints made noise moving them around by hand. I'm very happy with the result, the jeep feels a lot better to drive, it coasts longer, and is faster, I'm sure this will help my gas mileage as well! :thumbs:
I had the privilege of competing in the SAE Supermilage Competition this year. It is similar to your train of thought, except the speeds are regulated to be very low (although you wouldn't want to go fast since drag force is a squared function where doubling speed = quadrupling drag force). It becomes a competion less about engine innovations and more about minimizing drag or specifically rolling well. This unfortunately has little impact on cars on the street as far as I have seen. Most car manufacturers seem to show off new engine developments rather than new bearing developments. Just by testing different bearing in real world applications we were able to roll about 25% further than last year. Good luck getting a 25% increase in efficiency from an engine unless it is not running properly.
