Am i "riding the clutch" if i do this?
Hello people, my name is Ryan, i'm new here.
I have a question. Let's say i'm slowing down (released the gas) and my
speed is somewhere between 1st gear and 2nd gear speeds, then i need to
accelerate again. Am i "riding the clutch" if i accelerate from 2nd gear
but "help" it a bit by slightly depressing the clutch at first? just so the
car doesn't shake?
Because if i switch to 1st gear instead, the revs are too high and the
engine is unhealthily loud.
put her in neutral, neutral never hurts :thumbs:
Yes, you are riding the clutch when you do that.
Look, if it lugs in second gear because you are going to slow for that
gear, then putting it in 1st gear will not rev your engine "too high."
I guess you mis-understood. :screwy:
Thanks. Perhaps i do get a bit paranoid about the car shaking if i don't apply the clutch a bit.
You shouldn't let the car shake rattle and roll you should downshift a gear. :thumbs:
don't release the clutch too quick
You can release the clutch as fast as you want when you're changing from 1
to 2.. 2 to 3.. etc. It's just from a dead stop that you have to ride it a
little (well not HAVE to :wink2: )
When changing from one gear to another, you want the motor to be between
1000-1500RPM in the gear you are changing to, it's bogging down the car
because you're not giving it any gas, you have to give it gas (after you've
de-clutched) and get 'er up to near 2grand to get a nice smooth ride.
