My Geo Prizm 1991 likes to overheat...
And I think it's mostly that the engine is old. If I sit at a red light too
long, the temperature guage needle will show that the temperature has risen
over the halfpoint. If it goes up further, the fan will kick in. Someone
here said that the fan waits until it detects 100 Celcius before it kicks
on. Is this true?
Is it possible to change the settings so that the fan will come on at a
lower temperature, so as to prevent the needle from going halfway? I know
it isn't a failure with the needle, because I recently had the sensors (is
that what they are called?) replaced. Also, whenever the needle goes beyond
the halfpoint my car shows other signs of getting too hot, such as
vibrating harder. Not a nice thing. Makes me nervous. And how am I supposed
to drive it around in the summer like that? It will be overheating more
intensely and more often.
My question is, is there a problem with my fan? And if so, how do I fix it?
And if there is no problem with the fan, then I will need to adjust the
kick-on temp. How would I do that?
t-stat maybe? not opening right or something..you leaking anything?, you have heat? im not a mechanic so wait til one knows about those cars :cool2:
100's high, but not un-common. Think of it this way, your thermostat
doesn't open until probably about 90-110 degrees, depends on the thermostat
you have in it.
What's half-way? what does the gauge read? because normally, half-way is
where it is supposed to be. Just as long as it doesn't redline it's fine.
It's cold in winter, so the car runs cooler, now it's getting warmer so
you're car is starting to run warmer, is that all you're experiencing?
My car will go well passed the half-way point all the way up to 115 or 120,
then once the thermo opens it'll drop to about 60. Coolant temp light stays
on but it doesn't matter, as long as it doesn't get passed about 125 it's
good.
