any other ways?
Home  \  Off Topic  \  any other ways?
are there any other ways to increase the horsepower on a car other than, horsepower chips, muffler exhaust systems, and air intakes? i'm looking for relatively inexpensive ways to increase horsepower
posted by  V960
Hollowing out the catalytic converter, putting in a higher flowing air filter, and using premium gas will help your cars performance. You could also install better spark plugs, and spark plug wires.
posted by  SlipKnoT
yeah that is about it! But what kjind off car do you have juyst go on ebay and you can find some good cheap performance stuff
posted by  mx3_monster
only problem with hollowing out the catalytic converter is that there's the possibility that you could fail smog tests for your car's inspection. unless you have someone on the inside where you get your car inspected, that will gladly let it slide. then you're fine.
but yeah, slipknot is correct on the other ways - you can probably find cheap aftermarket ignition systems and air filters on eBay...but the premium gas could cost you an arm and a leg! seeing gas prices nowadays :banghead: :cussing:
posted by  SuperJew
Yeah, the gas prices over here just went up 30 cents today! :fu:
posted by  SlipKnoT
You could also try an CAI. They're not too expensive, but help a little bit.
posted by  Nissan_Altima
Woah, sorry, didn't see "are there any other ways to increase the horsepower on a car other than, horsepower chips, muffler exhaust systems, and air intakes?"
