alpine and infinity
Home  \  Off Topic  \  alpine and infinity
hi i just got a alpien mrd-m605 amp its a monoblock and i just saw the new infinity 8" subs the reference ones that are 200min/800max. is the alpine amp that i got have enough power to power bolth infinity subs like those? the specs are:
Bass Engine®
-Crossover Type : 24dB/Octave Low Pass - Digital
-Low Pass Crossover Frequency (Selectable) : 30Hz - 200Hz (1/6 oct. Steps or Off)
-Subsonic Filter Range : 15Hz - 50Hz (5Hz Steps) or OFF
-Subwoofer Phase Control : Normal (0°) or Reverse (180°)
General-Amplifiers
-Frequency Reponse : 20Hz-200Hz (±1dB)
-Heat Sink (WxHxD)in : 7-31/64" x 2-5/16" x 8-11/16"
-Heat Sink (WxHxD)mm : 190mm x 60mm x 220mm
-Input Impedance : 100k Ohm
-Input Sensitivity (for rated power) : 0.1V to 8.0V
-Signal to Noise (S/N) : 90dBA (referenced to rated power)
-Speaker Impedance : 4 or 2 ohms (Mono)
-Weight : 3.9kg (9lbs. 5oz.)
-MAX Power (at 14.4V,EIAJ)
Per channel into 2 ohms : 900W x 1
-RMS Power (at 12V,20Hz-200Hz)
Per channel into 2 ohms : 400W x 1
Per channel into 4 ohms : 250W x 1
-RMS Power (at 14.4V,20Hz-200Hz)
Per channel into 2 ohms : 600W x 1
posted by  nick27
that amp should be fine with those subs
posted by  bigdaveangell
eww an alpine amp, EWWW reference subs...dont tell me u wasted more than 150 on taht ...stuff....
posted by  Stem
