question about swap?
Home  \  Repairs & Maintenance  \  question about swap?
I was wondering if it is possible to swap the ka24de engine into the 89 240sx without customizing anything or taking out the ac???? And i was wondring what part i might need to make the swap a successful?
posted by  luck777
I have done a few. and when you need to make any rods for linkage get small pipe compression fittings also make a rought mount then you can make the finished one with the extra bracing needed and they look alot better. don't line the drive shaft straight angle it alittle on it will hippity hop. Jim
posted by  jireman
