oil leak
Home  \  Repairs & Maintenance  \  oil leak
i have 98 tercel 5e-fe automatic. i have noticed an oil leak which appears to be coming from around the oil pan or somewhere close to it. would it be worth replacing the gasket/pan only to find out that leak is coming from somewhere else, rear main seal maybe. also is anyone familier with the amount of road noise these cars produce. i'm wondering if a bearing or cv joint is dry or worn.
thank you
posted by  ephraim
