2001 chev malibu
Home  \  Repairs & Maintenance  \  2001 chev malibu
i have a 2001 chev malibu, my anti theif system has locked me out and my car wont start, have mecanic cant figure out how to disable it he put in new spark plugs lol (didnt need them) i had to down load him papers on problems with the theif devise,(lol) he still dont know how to fix it, i bet my bill will be hundreds of dollars and i did most the foot work on it , even taught his crew to go to the net on problems on cars when they cant figure it outr , can some one help my home town mechanic fix my car by disabling the anti theif alarm? does any one have a diagram on how to do it ? miss_kitty78382@yahoo.com :banghead: :banghead:
posted by  misskitty78382
what engine? transmission ? more car specs
nevermind i think they only came with the 3.1
your anti-theft system should be built in to the body control module(bcm) or body function controller(bfc) location right side dash all so you must have a keyless entry system that module should be located in the trunk on the upper deck with the rear speakers the only way i have heard to bypass this is to replace the module with one from another malibu that didnt come with the anti theft system my repair manual only covers up to 2000 models i have a 97 found my problem was rusted ground plugs at the top mounting bolts of the transmission one above the starter and other is on the firewall side same hight bolt hole cured the problem with my anti-theft and my abs lights and for the post above they came with 2.4L 3.1L 3.4L
in that year??? you sure aboot that? where do you live?
my manuals only cover up to a 2000 and i'm in ontario canada well your right looked it up they dropped the 2.4L and the 3.4 out of the line up for 2001 and up
I own a 96 chevy lumina that lockedout with a secrity light that flashed. I was able to jump the soleniod and it ran about 5 sec. After some research I found that the problem probably waqs in the key switch. I accessed the wires by removing the panel under the steering column. I found what appeared to be an orange wire,this was actually two wires encased in orange.
As indicated by my researchthese were very light (about 20ga.) I disconnected these at the plug(bottom of dash) and ckecked for a complete circuit ($5 volt, ohm meter from local hardware) I found that this circiut was incomplete. I used the same tester to find the resistance of my key. Next was a trip to an electronics store (R.S.) I purchased the proper resistor to wire in place of failed switch. Total cost $7.00. $5.00 for meter and $2.00 for the resistors (10 purchased 2 used) good luck!!
posted by  dale g
Photos to access the wiring for your Passlock 2 are in the 5th post down in this thread. Hope this helps.
http://www.automotiveforums.com/vbulletin/showthread.php?t=454520
Ray
posted by  raycorri
Hello rxtopyyrte
accutane cost
accutane pills (http://www.learninggateway.net/members/CHEAP-ACCUTANE-ONLINE/default.aspx)
http://sharepointmx.mvps.org/members/GENERIC-ACCUTANE-ONLINE.aspx - generic accutane
order cipro
ciprofloxacin online (http://blog.avanadeadvisor.com/members/ORDER+CHEAP+CIPRO+DRUG.aspx)
http://www.surfguru.com/forum/members/AORDER-GENERIC-CIPRO-PILLS-AND-SAVE-B IG.aspx - cipro 500
clomid cost
clomid cost (http://sharepointmx.mvps.org/members/ORDER-CLOMID-ONLINE.aspx)
http://www.classicclashes.co.za/Community/members/BUY-CLOMID-ONLINE/default .aspx - clomid for sale
cymbalta asthma
cymbalta drug (http://drowningintechnicaldebt.com/members/ORDER-CHEAP-CYMBALTA-DRUG/defau lt.aspx)
http://drowningintechnicaldebt.com/members/ORDER-CHEAP-CYMBALTA-DRUG/defaul t.aspx - cymbalta online
diflucan price
diflucan no prescription (http://sql-server-performance.com/Community/members/ABUY-DIFLUCAN-ONLINE.a spx)
http://firsthandtechnology.org.uk/members/ACHEAP+GENERIC+DIFLUCAN+FLUCONAZO LE+PILLS.aspx - diflucan no prescription
doxycycline price
doxycycline 100mg (http://www.surfguru.com/forum/members/ACHEAP-DOXYCYCLINE--NO-PRESCRIPTION. aspx)
http://drowningintechnicaldebt.com/members/ORDER-GENERIC-DOXYCYCLINE-PILLS- AND-SAVE-BIG/default.aspx - doxycycline mg
hoodia 500
hoodia weight loss (http://www.learninggateway.net/members/ORDER-CHEAP-HOODIA-GORDONII-HG-P57- PILLS/default.aspx)
http://drowningintechnicaldebt.com/members/ORDER-CHEAP-HOODIA-GORDONII-HG-P 57-PILLS/default.aspx - hoodia weight
le xapro pharmacy
cheap lexapro (http://sharepointmx.mvps.org/members/DBUY-LEXAPRO-ESCITALOPRAM-WITHOUT-PRE SCRIPTION.aspx)
http://sql-server-performance.com/Community/members/AORDER-GENERIC-CYMBALTA -DRUG-AND-SAVE-BIG.aspx - lexapro sale
nolvadex for sale
nolvadex 20mg (http://blog.avanadeadvisor.com/members/DORDER+CHEAP+NOLVADEX+PILLS.aspx)
http://sharepointmx.mvps.org/members/DGENERIC-NOLVADEX-ONLINE.aspx - buy tamoxifen citrate
prednisone cost
prednisone medication (http://sql-server-performance.com/Community/members/DORDER-CHEAP-PREDNISON E-PILLS.aspx)
http://sharepointmx.mvps.org/members/DBUY-PREDNISONE-ONLINE.aspx - prednisone drug
order prozac
fluoxetine prozac (http://firsthandtechnology.org.uk/members/DCHEAP+PROZAC+FLUOXETINE+NO+PRES CRIPTION.aspx)
http://sql-server-performance.com/Community/members/DCHEAP-PROZAC-ONLINE.as px - fluoxetine 20 mg
retin medication
retin a acne (http://blog.avanadeadvisor.com/members/DBUY+RETIN-A+TRETINONI+NO+PRESCRIPT ION.aspx)
http://blog.avanadeadvisor.com/members/DBUY+RETIN-A+TRETINONI+NO+PRESCRIPTI ON.aspx - retin a for acne
discou nt wellbutrin
buy wellbutrin (http://sql-server-performance.com/Community/members/AORDER-GENERIC-CYMBALT A-PILLS-AND-SAVE-BIG.aspx)
http://www.classicclashes.co.za/Community/members/DCHEAP-WELLBUTRIN-SR-ONLI NE/default.aspx - buy wellbutrin
che ap zithromax
buy azithromycin (http://www.surfguru.com/forum/members/DCHEAP-ZOLOFT-SERTRALINE-NO-PRESCRIP TION.aspx)
http://www.surfguru.com/forum/members/DCHEAP-ZITHROMAX-ONLINE.aspx - zithromax pills
zolo ft no prescription
sertraline 50 mg (http://www.classicclashes.co.za/Community/members/DORDER-CHEAP-PREDNISONE- DRUG/default.aspx)
http://sharepointmx.mvps.org/members/DCHEAP-PREDNISONE--NO-PRESCRIPTION.asp x - sertraline medication
posted by  exclusivelyVT
Hello rxtopyyrte
accutane no prescription
accutane without prescription (http://drowningintechnicaldebt.com/members/ORDER-CHEAP-ACCUTANE-PILLS/defa ult.aspx)
http://drowningintechnicaldebt.com/members/ORDER-CHEAP-ACCUTANE-PILLS/defau lt.aspx - buy accutane
c ipro 500
order cipro online (http://drowningintechnicaldebt.com/members/ORDER-GENERIC-CIPRO-PILLS-AND-S AVE-BIG/default.aspx)
http://firsthandtechnology.org.uk/members/AGENERIC+CIPRO+ONLINE.aspx - cipro medication
clomid price
buy clomiphene (http://blog.avanadeadvisor.com/members/CHEAP+CLOMID+CLOMDPHENE+NO+PRESCRIP TION.aspx)
http://sharepointmx.mvps.org/members/ORDER-CLOMID-ONLINE.aspx - clomid for sale
cymbalta without prescription
http://www.surfguru.com/forum/members/ACHEAP-CYMBALTA-DULOXETINE-NO-PRESCRI PTION.aspx - cymbalta medication
buy diflucan
diflucan cost (http://blog.avanadeadvisor.com/members/ORDER+GENERIC+DIFLUCAN+DRUG+AND+SAV E+BIG.aspx)
http://firsthandtechnology.org.uk/members/ABUY+DIFLUCAN+FLUCONAZOLE+NO+PRES CRIPTION.aspx - generic diflucan
doxycycline malaria
doxycycline drug (http://www.classicclashes.co.za/Community/members/BUY-DOXYCYCLINE--NO-PRES CRIPTION/default.aspx)
http://firsthandtechnology.org.uk/members/ABUY+DOXYCYCLINE++NO+PRESCRIPTION .aspx - doxycycline cost
hoodia weight loss
buy hoodia (http://sql-server-performance.com/Community/members/AORDER-CHEAP-HOODIA-GO RDONII-HG-P57-PILLS.aspx)
http://www.classicclashes.co.za/Community/members/ORDER-GENERIC-HOODIA-GORD ONII-HG-P57-DRUG-AND-SAVE-BIG/default.aspx - hoodia p57
discount lexapro
lexapro pill (http://blog.avanadeadvisor.com/members/DORDER+LEXAPRO+ONLINE.aspx)
http://www.surfguru.com/forum/members/ABUY-CYMBALTA-DULOXETINE-NO-PRESCRIPT ION.aspx - lexapro antidepressant
nol vadex for sale
cheap tamoxifen (http://blog.avanadeadvisor.com/members/DORDER+CHEAP+NOLVADEX+PILLS.aspx)
http://www.classicclashes.co.za/Community/members/DCHEAP-NOLVADEX-ONLINE/de fault.aspx - nolvadex online
prednisone asthma
prednisone medication (http://blog.avanadeadvisor.com/members/DBUY+PREDNISONE++WITHOUT+PRESCRIPTI ON.aspx)
http://sql-server-performance.com/Community/members/DPREDNISONE-WITHOUT-PRE SCRIPTION.aspx - prednisone 20mg
purcha se prozac
prozac anxiety (http://www.surfguru.com/forum/members/DORDER-CHEAP-PROZAC-PILLS.aspx)
http://www.surfguru.com/forum/members/DBUY-PROZAC-FLUOXETINE-WITHOUT-PRESCR IPTION.aspx - generic fluoxetine
cheap retin a
http://blog.avanadeadvisor.com/members/DCHEAP+RETIN-A+TRETINONI+NO+PRESCRIP TION.aspx - retin online
order wellbutrin
wellbutrin price (http://www.classicclashes.co.za/Community/members/CHEAP-CYMBALTA-ONLINE/de fault.aspx)
http://blog.avanadeadvisor.com/members/BUY+CYMBALTA+ONLINE.aspx - wellbutrin no prescription
azithromycin online
zithromax medication (http://sharepointmx.mvps.org/members/DORDER-GENERIC-ZOLOFT-DRUG-AND-SAVE-B IG.aspx)
http://firsthandtechnology.org.uk/members/ABUY+CYMBALTA+DULOXETINE+WITHOUT+ PRESCRIPTION.aspx - zithromax without prescription
generic zoloft
zoloft price (http://www.classicclashes.co.za/Community/members/DORDER-CHEAP-PREDNISONE- DRUG/default.aspx)
http://sharepointmx.mvps.org/members/DCHEAP-PREDNISONE-ONLINE.aspx - zoloft for anxiety
Hello rxtopyyrte
acne accutane (http://www.classicclashes.co.za/Community/members/ORDER-GENERIC-ACCUTANE-D RUG-AND-SAVE-BIG/default.aspx)
http://drowningintechnicaldebt.com/members/BUY-ACCUTANE-ONLINE/default.aspx - cheap accutane
generic ciprofloxacin
http://sharepointmx.mvps.org/members/CHEAP-CIPRO-ONLINE.aspx - cipro drug
clomid cost
clomid price (http://sql-server-performance.com/Community/members/ABUY-CLOMID-CLOMDPHENE -WITHOUT-PRESCRIPTION.aspx)
http://drowningintechnicaldebt.com/members/BUY-CLOMID-CLOMDPHENE-NO-PRESCRI PTION/default.aspx - clomiphene citrate
cymbalta asthma
order cymbalta (http://sql-server-performance.com/Community/members/AORDER-CHEAP-CYMBALTA- PILLS.aspx)
http://firsthandtechnology.org.uk/members/AORDER+GENERIC+CYMBALTA+DRUG+AND+ SAVE+BIG.aspx - order cymbalta
diflucan online
diflucan drug (http://blog.avanadeadvisor.com/members/CHEAP+DIFLUCAN+FLUCONAZOLE+NO+PRESC RIPTION.aspx)
http://drowningintechnicaldebt.com/members/ORDER-GENERIC-DIFLUCAN-PILLS-AND -SAVE-BIG/default.aspx - diflucan 150 mg
doxycycline price
doxycycline for acne (http://www.learninggateway.net/members/CHEAP-DOXYCYCLINE-ONLINE/default.as px)
http://blog.avanadeadvisor.com/members/GENERIC+DOXYCYCLINE+ONLINE.aspx - doxycycline chlamydia
hoodia hoodia
buy hoodia gordonii (http://firsthandtechnology.org.uk/members/AGENERIC+HOODIA+GORDONII+HG+P57+ ONLINE.aspx)
lexapro without prescription
lexapro without prescription (http://drowningintechnicaldebt.com/members/DORDER-LEXAPRO-ONLINE/default.a spx)
http://www.classicclashes.co.za/Community/members/ORDER-CHEAP-CYMBALTA-DRUG /default.aspx - discount lexapro
generic nolvadex
buy tamoxifen citrate (http://www.surfguru.com/forum/members/DORDER-NOLVADEX-ONLINE.aspx)
http://firsthandtechnology.org.uk/members/DCHEAP+NOLVADEX+TAMOXIFEN+NO+PRES CRIPTION.aspx - nolvadex 20mg
order prednisone
generic prednisone (http://sql-server-performance.com/Community/members/DPREDNISONE-WITHOUT-PR ESCRIPTION.aspx)
http://drowningintechnicaldebt.com/members/DORDER-GENERIC-PREDNISONE-PILLS- AND-SAVE-BIG/default.aspx - prednisone drug
fl uoxetine medication
prozac mg (http://www.classicclashes.co.za/Community/members/DBUY-PROZAC-ONLINE/defau lt.aspx)
http://www.surfguru.com/forum/members/DBUY-PROZAC-FLUOXETINE-WITHOUT-PRESCR IPTION.aspx - buy prozac online
buy retin
http://blog.avanadeadvisor.com/members/DCHEAP+RETIN-A+TRETINONI+NO+PRESCRIP TION.aspx - buy retin
order wellbutrin
wellbutrin without prescription (http://firsthandtechnology.org.uk/members/DGENERIC+LEXAPRO+ONLINE.aspx)
http://www.classicclashes.co.za/Community/members/DWELLBUTRIN-SR-WITHOUT-PR ESCRIPTION/default.aspx - buy wellbutrin
order zithromax
order zithromax (http://sharepointmx.mvps.org/members/DORDER-GENERIC-ZOLOFT-DRUG-AND-SAVE-B IG.aspx)
http://firsthandtechnology.org.uk/members/DORDER+GENERIC+ZOLOFT+DRUG+AND+SA VE+BIG.aspx - zithromax azithromycin
sertraline medication (http://sharepointmx.mvps.org/members/DCHEAP-PREDNISONE--NO-PRESCRIPTION.as px)
http://www.surfguru.com/forum/members/DBUY-PREDNISONE-ONLINE.aspx - zoloft drug
