97 Olds Cutlass Supreme Signaling problem
Home  \  Repairs & Maintenance  \  97 Olds Cutlass Supreme Signaling problem
I have a prblem with the signal lights on my 97 Olds Cutlass Supreme. When I turn on my signal either way the green directional light on the instrument panel comes on and stays on and does not blink. When I thought maybe it was just the instrument panel I checked the lights on the outside and they do the same. It is weird because the four light flashers work fine when I turn them on. Any help in this matter would be great.
Thanks,
Andrew
posted by  lightbody
I believe there is a turn signal relay that must need replacing. Same was with my car and replacing the relay fixed the problem.
posted by  BavarianWheels
BW is probably correct in his assumption. Your car has seperate flasher units for the emergency flashers and the turn signals. You most likely have a turn signal flasher that has simply crapped out. Replacement flashers are available for about $7 to $10 at your local car parts store.
Thank you both for your input. This was exactly the problem and it took about 10 minutes to fix.
Thanks again,
Andrew
posted by  lightbody
