-- -- -- Would it be ok to use an entire bottle of Stop Leak oil additive...???
Home  \  Repairs & Maintenance  \  -- -- -- Would it be ok to use an entire bottle of Stop Leak oil additive...???
Just curious to know if its ok to use an entire bottle or only half bottle of that additive that helps stop leaks for my engine...??
Would it be harder on the engine or any consiquences ??
Its the Lucas brand oil
Lucas Oil (http://www.lucasoil.com/index.sd)
posted by  Rad1
read the bottle most additive they say to add the whole bottle but make sure you are down a quart in oil or do it with an oil change and minus one liter of oil for the additive i haven't heard any bad things about the lucas brand i used the oil additive in a stock car(86 mustang 4cyl class) never had any failure caused by oil i dont know if you have seen there little display unit the set of gears you spin the oil dosn't make it to the top then the other has the lucas in it and it makes it to the top and is coating the gear
Ya i looked on the bottle but didnt see anything about how much to put, ill check again...thanks for the info.
posted by  Rad1
