mustangman
Home  \  Repairs & Maintenance  \  mustangman
I have a 1968 mustang 289cu in engine, It will not turn off with the key, I have replaced the Ing switch, solenoid starter relay & regulator, none of this has solved the problem, have also cleaned battery post, and post on the starter, I also have on this car which came factory the swing away steering wheel, could there be a switch there that could have gone bad?
Thanks for any help anyone can give me,
Mustang man
posted by  gardjerry
your going to need to check the wires from coil back to the switch maybe the ignition switch wires crossed your not shutting down the power to the coil
