89 chevrolet corsica
Home  \  Repairs & Maintenance  \  89 chevrolet corsica
how to set idle speed on a 89 chevrolet corsica, thank
you
from corsicamom
posted by  corsicamom
im gunna have to refuse to supply info until you read the TOPIC OF posting and U! please just read it and i will try to help you
the idle speed is controlled by the iac(idle air control) valve there's no adjusting unless you replace the valve. is the service engine light on
hi this is corsicamom
the service engine light is on
you will need to have the codes read from the computer in the car this will give you the source of the problem with the engine if the idle is low or rough there maybe problems with a sensor(s)
this is corsicamom
ok i'll do that, thank you very much
