Leaking 98 Grand Cherokee
Home  \  Repairs & Maintenance  \  Leaking 98 Grand Cherokee
My 98 Jeep leaks (AC) leaving water pooled on the passenger floor. I checked the archives and found a similar thread re: 94 Cherokees with this same issue, but the solutions don't seem to apply to my newer Cherokee. What is the process to access whatever drain or port is plugged up?
Thanks...
posted by  pauldav1d
what do you mean by AC leaking? is it leaking water? or is it also leaking refrigerant and losing pressure? a pool normal pool of water is nothing to be concerned about.
i may be off, more info possibly?
posted by  carls47807
The answer to the original question should be the same as the other thread.
posted by  srober32
