vw passat overheating
Home  \  Repairs & Maintenance  \  vw passat overheating
i have a 1992 passat, gl, 2 litre with 16 valves. car keeps overheating. I have changed the cap, rad sensor, belt, thermostat, fluid level ok. I'm very stumped. Need help. Rad seems ok
posted by  lismik
what set this off, did it happen suddenly, or after you had something serviced. could be an unbled cooling system.
does it happen all the time or just when you are idling at a stoplight or something? it could be a bad temperature switch or radiator fan motor.
~good luck
posted by  carls47807
