95 dodge neon wheel bearing replacement
Home  \  Repairs & Maintenance  \  95 dodge neon wheel bearing replacement
anyone here done the whole press in thing with dodge neon wheel bearings? and can i pull the hub assembly without pulling the balljoint and tie rod end?
(haven't even pulled the wheel yet) thanks for the input.
~carl
posted by  carls47807
Well, I think you have to pull the ball joint to get the driveshaft out, 'cause with it in and the retaining nut on the bearing shouldn't come off. :2cents:
posted by  srober32
i plan on pulling the spindle nut and unbolting the hub, there shouldn't really be a need to pull the driveshaft should there?
i guess i'll have to see what needs to be done tomorrow, and i'll let you know.
Well?
posted by  srober32
got called into work, i'll let you know friday night how it pans out.
Cool! :thumbs:
posted by  srober32
