Dying
Home  \  Repairs & Maintenance  \  Dying
I have a 1995 Plymouth Voyager van. The van was running perfect last night. The first time I started it this afternoon the van kept dying everytime I reduced speed, stopping at a stop sign, going around a corner. I would have to stop completely and restart the car and then it would go until I reduced speed again. It is an automatic. What could be wrong?
posted by  bobbiji
try this.
start it up. run it at high rpms for a couple of minutes (2000), and then let off the gas and see if it stalls. if not your overdrive is probably not disengaging. did you recently have a fluid change? maybe they put the wrong tranny fluid in it, should be atf+3.
try locking it in 3rd or 2nd gear (if it is a 3 speed) and go as fast as you feel comfortable. then slow down and see if it still stalls. if it doesn't you probably have a bad lock up torque converter/solenoid or something along those lines.
Is it a 3 speed or a 4 speed, maybe i can help you out more.
posted by  carls47807
Clean the throttle body & see what that yields.
no service engine light
1 your air filter would have to be plugged badly to cause a stall
2 idle air control valve is defective
3 egr valve leaking or stuck open
4 vacuum leak check vacuum hose's
5. bad compression
6. needs new plugs
7. needs new wires
8. needs new cap
9. needs new rotor
10. bad gas
11. fuel pump shot
12. rear tires bald
13. brakes in front need to be done
exactly i don't see how this guessing game helps anyone :ohcrap:
14. turn signal fluid low
15. canuter valve stuck open
16. defombulator valve stuck closed.
17. glow plugs gapped incorrectly
18. tires on wrong sides of car
...come on banff--this is fun!! :drool: :drool: :drool:
posted by  dodger65
19. missing tire valve caps
20. MAP is shot
21. MAF is shot
22. TPS is shot
23. PCM BCM TCM DRL and the PIDS are foobar
and finally it's a P.O.S
24. The all important Muffler bearings
(Sorry, I couldn't resist! lol)
posted by  srober32
lets not forget he never said there was no check engine light? where is this guy anyways, here we are eager to help and he's skipped town. i've never understood that type of person, posting their question on a forum and then vanishing "like a fart in the wind"
Maybe he has another car and decided to check back in a couple of days, he only posted yesterday.
posted by  srober32
1. He is a she.
2. Was weekend, kids home.
3. Checked plugs, yechhhh.
4. Changed plugs.
5. Not doing it anymore
6. THANKS A BUNCH!!
:thumbs:
posted by  bobbiji
1. He is a she.
4. Changed plugs.
6. THANKS A BUNCH!!
:thumbs:
posted by  bobbiji
