2000 Saturn SL -DTC PO341...? Please Help!
Home  \  Repairs & Maintenance  \  2000 Saturn SL -DTC PO341...? Please Help!
00 Saturn SL- Code 341 but NO Cam Pos Sensor. Now What...?
Hi. Well my 2000 Saturn SL has 122,000 miles. Shortly after I bought it 3 weeks ago the "Service Engine Soon" light came on and has remained on.
I did an oil change, new Bosch plugs (the expensive ones) & wires thinking this would help but it didn't, not the light anyway.
After finding a Haynes manual and reading up a bit I purchased a code reader thinking it would be my crystal ball. It shows the mysterious 341 code & a pending 341 code; "Camshaft Position Sensor A - Bank 1 CKT Range/Perf".
My manual makes no reference to any Camshaft Sensor or I would've replaced it days ago.
The only thing I notice performance wise is when it's idling, it feels like it's missing here & there... that studder thing. I suspect it's effecting gas mileage/performance but not sure because it's been this way since the day after I bought it. Seems to run good though considering...
Can someone please clue me in on what to do now...? :banghead:
Thank you...
p.s. There is NO Camshaft Position Sensor on my engine, I've figured that much out. Now will someone who also knows that tell me why & how to fix what's causing the 341 code...? :banghead:
posted by  drummer1966
you code 0341 has to do with your cam shaft sensor your computer use's the signal from the sensor as well as the crankshaft sensor to adjust fuel injection timing and engine timing you are likely getting this code because the cam sensor is failing and needs to be replaced use the manual if you fell comfortable and test the cam sensor or take it in to your favorite shop and let them test it
I know this thread is ancient, but for anyone who has the misfortune to read the reply, don't waste your time. The car doen't have a Camshaft Position Sensor (CMP). Sorry.
same thing happened to me with my 92 saturn sl. it ended up being a perch sylinoid.it needs to be put on a diagnostic machine to find out the code then taken to a shop.
posted by  boobookittynca
july 2007 called, they want their post back.
posted by  carls47807
I like that, lol....But where did you get July 2007 from? :laughing:
posted by  Cliffy
oops, that would be june.
eh to clear it up even though its old its a eds module underneath the coil packs :thumbs:
posted by  stylesp
