My 2000 Olds Alero
Home  \  Repairs & Maintenance  \  My 2000 Olds Alero
On my Alero, the brake light bulbs are lit but when you press the brakes, they do not brighten up to make people aware of the fact that I'm stopping. Does anyone know what the problem could be?
posted by  Cammie
1 are you sure the lights you see on are the brakes and not the park lights
2 if you are sure then check the high mount(back window or trunk lid)does it light or check all the bulbs if they are good then check the fuse for the stop lights if good check the brake switch under dash on the brake pedal this switch will also be the same switch that cancels your cruise control
