95 neon crank gear
Home  \  Repairs & Maintenance  \  95 neon crank gear
i had a question about pulling off the crank gear on a 95 dodge neon DOHC. the haynes manual i have says you can just use a bolt-type gear puller, which i tried with absolutely no luck. i was wondering if anyone has run into this same problem or if there is a different tool i should be using or if there's some kind of retainer clip holding it on in place? i'm pretty much stuck and thought i'd ask before breaking anymore tools.
posted by  kcorb
i think there was a thread about this already, my only suggestion is rent the proper puller from your local chrysler dealership or find the snap-on pimp and buy a good puller from him :mrgreen:
